05-27-2013, 10:15 AM | #1 |
Rock Stacker Join Date: Apr 2011 Location: bergan
| Wraith links on scx10
Currently I am running the proline 2007 4-door chevy Silverado body on my scx10. The wheelbase of the body is 13". Is it possible to use links from the wraith to achieve this or has anyone achieved this wheelbase using axial spacers. Thanks in advance!
05-27-2013, 10:49 AM | #2 |
Pebble Pounder Join Date: Jan 2013 Location: Zürich
I d suggest u measure the wraith wheelbase and that will tell you if it works.i m running the wraith titanium links on my rubicon.
05-27-2013, 11:21 AM | #3 |
Rock Crawler Join Date: Jan 2013 Location: Laguna Niguel
| Re: Wraith links on scx10
Keep in mind the wraith skid Is longer.
05-27-2013, 12:20 PM | #4 |
Quarry Creeper Join Date: Mar 2013 Location: Moscow Russia
So you measure Wraith links and compare them to SCX10. I think Wraith links are shorter. It is easier to pick new links and make wheel base you want. You can make them yourself or order from RC4WD, they have variety of sizes. I did second, here are calculations to make 13" wheel base. Last edited by nersik; 05-27-2013 at 12:26 PM. |
05-27-2013, 12:22 PM | #5 |
Rock Crawler Join Date: Dec 2005 Location: Huntertown, In
Wraith links are 87.5mm, and SCX(Honcho) are I think 97mm and 106mm. I think if you use both 101mm or maybe 106mm you'll get 13"wb as the stock Honcho is 12.5" Misspelled using Tapatalk to aggravate the grammar Nazis!!! |
05-27-2013, 12:56 PM | #6 |
RCC Addict Join Date: Mar 2009 Location: Interior BC
im currently working on a scx10 with wraith axles....the links from the wraith throw the caster off the charts. Youll need to measure what you need and either find ones that will work for you or fab your own.
05-29-2013, 02:54 AM | #7 |
I used a mix of the vanquish titanium links for the currie axles and the wraith links. |
05-29-2013, 04:45 AM | #8 |
Quarry Creeper Join Date: Sep 2010 Location: Gettysburg
could just make your own links. what I did to get a 13inch wheelbase for my Silverado
