05-30-2013, 12:47 PM | #1 |
Newbie Join Date: Jan 2013 Location: Downingtown
| Vanquish question
What is the difference between the: 1) VP Axial High Steer Knuckles ($34.99) 2) VP Axial SCX10 8 Degree Knuckles ($42.99) 3) VP Axial AX10 High Steering Knuckles Zero Acker ($34.99) 2 & 3 are listed as a replacement for AX30496, and both are listed as Zero Ackerman (for a tighter turning radius). I understand that, but why three different models? Thanks! |
05-30-2013, 12:58 PM | #2 |
Rock Crawler Join Date: Feb 2012 Location: Michigan
| Re: Vanquish question
1 is ackerman high steer, 2 is for use with only their 8* c-hubs, and 3 is zero ackerman high clearance. 1 and 3 can be used with Axial or other manufacturers, while 3 needs to be used with the Vanquish 8* parts. Hope this helps.
05-30-2013, 01:56 PM | #3 |
Ahhh, makes more sense now. Thanks for the clarification! |
05-30-2013, 03:40 PM | #4 |
Rock Crawler Join Date: Jun 2009 Location: summertown
The zero akermans and standard high steer work with any axial Scx10 or ax10 Chub. The standard high steers accept the stock steering arm, the zero akerman have to have a custom length. 8° chubs will only work with 8° knuckles, wraith knuckles or ( Xr10 Knuckles Last edited by Twisted Nuts; 05-30-2013 at 03:46 PM. |
Vanquish question - Similar Threads | ||||
question for you all on vanquish wheels need some help | champ198 | Axial Wraith | 2 | 05-23-2013 05:01 PM |
Question about Vanquish Steering | XDR | Axial Wraith | 15 | 10-14-2011 05:04 PM |
noob vanquish question | Sixohh | Axial Wraith | 13 | 10-09-2011 05:00 PM |
Vanquish Revolver Question... | megacabcummins | General Scale Talk | 2 | 11-19-2008 12:48 PM |
