06-09-2013, 02:40 AM | #1 |
RCC Addict Join Date: Feb 2012 Location: UK
| IROK or TSL SX Super Swampers?
Hi folks. I found a weak spot in the Trepidors. On very loose surfaces I was left at the bottom of the hills whilst the Ripsaws did a lot better! I think it's the flatter tread pattern that caused the. Just not enough bite. The IROK or TSL SX Super Swampers look good. But which are better? |
06-09-2013, 04:27 AM | #2 |
Quarry Creeper Join Date: Sep 2011 Location: Lexington
I like both although I've only run the 2.2 TSL's. The 1.9 iroks perform great though on my Jeep. The 1.9 TSL's are closer in size to the Ripsaws while the iroks are much bigger.
06-09-2013, 09:57 AM | #3 |
RCC Addict Join Date: Feb 2012 Location: Ca.
| Re: IROK or TSL SX Super Swampers?
I have the IROKS on my Jeep and the Trepadors on my Honcho. I can't see any difference in grip on the rocks. The Treps are a little taller. I would have probably gone with the Treps on the Jeep also except for the fact that I have RC4WD Dick Cepek wheels on the Jeep and they don't fit the axial tires well due to the inner circumference of the Axial tires. Just thought I pass that info along in case your looking at a wheel purchase.
06-09-2013, 10:29 AM | #4 |
Quarry Creeper Join Date: Feb 2013 Location: hawkins
i was running tsl's on my honcho and they perform great in soft and lose dirt and rock but have not run with iroks. i went to ttc baja claws and i am not happy had to lift my truck to much to make them work and started popping my junfac drive shafts. thinking about going back to my tsl's
06-09-2013, 12:17 PM | #5 |
Quarry Creeper Join Date: Mar 2013 Location: Moscow Russia
I would recommend TSLs. I noticed X2SS compound in RC4WD Iroks is very sticky till you take it outside. Once it gets some dust all advantages are gone. It is like dough, stick to hands until you add some flour. |
06-09-2013, 02:59 PM | #6 |
Thanks folks....looks like the TSLs have the edge. The Treps have been awesome in every other condition I have ran in but that session....as I say it was like I was running slicks.
07-20-2013, 01:46 PM | #7 |
Newbie Join Date: Jan 2012 Location: British Crawlumbia, Canada
If you want the proline swampers don't forget to check out the new 1.9 xl size. |
07-20-2013, 01:56 PM | #8 |
Yup, make sure to get the new larger "xl" size TSL and you'll be happy. I just switched from cut n shut 2.2 TSL's to 1.9 IROKS and back to the 1.9 TSL once the new ones came out. |
07-20-2013, 01:58 PM | #9 |
| Re: IROK or TSL SX Super Swampers? |
07-20-2013, 05:44 PM | #10 |
Pebble Pounder Join Date: Oct 2008 Location: Oshawa, Ontario Canada
I've run the TSL 1.9 Swampers the first gen small ones and they worked well, I switched to the 1.9 IROC because I wanted more ground clearance worked as good as the TSL Swampers, now I run 1.9 Pit Bulls taller then the TSL's but just a bit shorter then the IROC's but work a lot better then both all around but I have yet to see or try the new 1.9 TSL Swamper that is taller I think they would be as good as if not better then the Iroc's...
07-20-2013, 09:50 PM | #11 |
Anyone have them mounted on a RC4WD wheel like maybe Dick Cepek's?
11-06-2013, 10:16 PM | #12 | |
Quarry Creeper Join Date: Jul 2012 Location: Missoula
| Re: IROK or TSL SX Super Swampers? Quote:
Change the geometry on the axles so ur shafts are more inline helped with my lift | |
11-07-2013, 04:58 AM | #13 |
Rock Crawler Join Date: Nov 2010 Location: the 'burgh'
Hey my man, I like my Treps too and found the same problem as you. If you want to keep them take a Dremel and cut-off wheel and open up all the lugs. One pass through the factory cuts and it changes the tire's personality. |
11-07-2013, 07:00 AM | #14 |
Pebble Pounder Join Date: Mar 2013 Location: Albuquerque
Proline swampers are a great tire. I run the xl, s
11-07-2013, 09:45 AM | #15 |
Quarry Creeper Join Date: Nov 2012 Location: Nampa
Tsl sx or Tsl Xl
11-07-2013, 08:01 PM | #16 |
depends on ur ride height, XL's if u have enough clearance to keep from rubbing SX's cuz there a bit smaller but same tire if u don't have the room for flexing. I use the SX's and there are awesome prolly never run another type tire for me. I have the extra room I might get me a set of XL's some day just because there just a bit taller,
11-07-2013, 09:33 PM | #17 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
| Re: IROK or TSL SX Super Swampers? Hey GDB85...got a pic of what you did to the treps ??
IROK or TSL SX Super Swampers? - Similar Threads | ||||
tsl super swampers 2.2 or 1.9 | rcjeeplover11 | Tires and Wheels | 6 | 03-16-2011 01:36 PM |
super swampers tsl the real way | supercrawlerfreak | Tires and Wheels | 60 | 12-29-2007 12:06 AM |
