Thread: Stock Gearing Questions!!
Old 11-22-2013, 03:19 AM   #1
Default Stock Gearing Questions!!
Hey guys i just need to know what the stock gearing is for the SCX10..
all i seem to find is people talking about 6:1 or 5:1 stuff like that and i dont get that!
could someone explain that to me?
Also.. Any recommendations Im running a HH Crawl Master 27t and BRXL, dont need a ton of wheels speed just looking for a good amount of torque!
thanks in advance!
Norm
NormanAbsher is offline   Reply With Quote
Old 11-22-2013, 04:06 AM   #2
Default Re: Stock Gearing Questions!!
Stock gearing for the RTR trucks are 87T spur gear and 20T pinion gear
you could try a 16T pinion and see how that does for you...You may can go more but always watch the motor temp..Heat is a motor killer and you want the best compromise between power and heat.
I personally run a 16T with an 87T spur with a custom 27T motor and have zero heating issues.
These recommendations are if you are running a 2s lipo..if you run a 3s or better you wont need to gear as low to acheieve you torque goal to crawl but will increase your chances of breaking driveline parts like the driveshafts or a trans gear or an axle.
6sharky9 is offline   Reply With Quote
Old 11-22-2013, 04:14 AM   #3
87 spur and 20 pinion is 4.35,87/14 is 6.2. I have 56/14 and Roc 412 3100kv in mine.
Try it out with 87/15-16 maybe?
Holt is offline   Reply With Quote
Stock Gearing Questions!! - Similar Threads
Gearing questions/help NormanAbsher Axial SCX-10 2 08-11-2013 09:33 PM
gearing questions ridgecrest78 Axial AX10 2nd-gen 5 09-30-2012 09:51 AM
Gearing Questions spankbomb General Scale Talk 6 05-06-2012 09:11 PM
gearing questions....... 1lowta Axial Wraith 14 03-13-2012 05:51 PM
gearing questions usa1man General Crawlers 2 11-02-2007 12:15 AM
