Thread: Honcho scrap blister pak bedsides...
Old 06-18-2013, 10:55 PM   #1
Default Honcho scrap blister pak bedsides...
OK... maybe not for everyone...
but I hate throwing useable things in the trash...
Anyway... bought two li-po's
and they came packaged in a blister pack/card.
So... before throwing those into the trash...
thought I'd see what I could do to use them some more first.
The blister paks aren't scale looking by any means...
I only thought to cover the opening that runs thru
and under the flat bed surface. (looks funky to me)
just a couple expectations for me...
...attempt of PTM to the primary body (failed that)
...assure tires do not rub at full articulation
short of the slight paint mismatch... good enough
li-po blister pak similar to mine...
mounting is simply replacing the 6 deck screws (3 per side)
those secure that deck to the cage.
I replaced the original deck screws with similarly sized cap bolts and nuts.
Du-bro 2-56 X 1/2" Cat. No. 310, Nuts = Cat. No. 560
pics of it mounted...
as you can see I didn't spend a much time with it...
I think it looks awrite... maybe a little better with time spent...
but I really want a full std bed... this is just a temporary thang
so tell me how much you hate it !?
it's not rocket science...
so I see no point of pictures showing 6 bolts and nuts securing
hopefully common sense would overcome. Lol
TacoCrawler is offline   Reply With Quote
Old 06-18-2013, 11:04 PM   #2
Looks great!
Sent from my MB886 using Tapatalk 4 Beta
mett1971 is offline   Reply With Quote
Old 06-18-2013, 11:12 PM   #3
Default Re: Honcho scrap blister pak bedsides...
not a bad idea. Way to stay GREEN and use the waste to build new items. Looks good.
J.
06ToasterBox is offline   Reply With Quote
Old 06-18-2013, 11:40 PM   #4
You might try slipping the bedsides underneath te diamond plating. It looks low. But good job and super creative!
Demodude is offline   Reply With Quote
Old 06-19-2013, 08:05 AM   #5
Great idea! Looks good too!
scrounge is offline   Reply With Quote
Old 06-19-2013, 10:59 AM   #6
Great idea. Very resourceful.
Griffin is offline   Reply With Quote
Old 06-19-2013, 11:29 AM   #7
i've thought about the same thing when i'm tossing various plastic things in the recycle. now that i've seen it, i'd say it looks better than half the attempts some others have made for their Honcho - good job!
Perkolator is offline   Reply With Quote
Old 06-19-2013, 11:51 AM   #8
I like it!
2manyprojects is offline   Reply With Quote
Old 06-19-2013, 04:24 PM   #9
briliant idea man,nice looking rig
Kitty is offline   Reply With Quote
Old 06-20-2013, 08:40 PM   #10
^ thanks a bunch for all your comments...
I was definitely looking for this mod, to be cheap to do...
and am fairly pleased with the outcome.
^ ~ still want a full bed tho' ~
Threw my money away, instead, on a Axial Link/Steer. kit, beadlocks, tires
and Axial's wheel weight system/ring(s). (X 8 rings/X 24 weight bars)
I went for another set of the ripshaws...
whereas my son wanted to try the taller Trepador's.
^ ~ two trucks needed outfitting ~
holy cripe that poop was expensive
I'm done buying chit fo' awhile !?
but waiting for someone to mfg'r 1.9 Hankook MT RT03's
cheers
another thang...
Old 06-20-2013, 11:52 PM   #11
Natedog's Avatar
Looks good and goof way to re-use,
Old 06-21-2013, 03:26 PM   #12
Dude that's bad ass.
GravelDuster is offline   Reply With Quote
Old 06-23-2013, 10:45 PM   #13
Good idea ... save the earth
But u need tail light .. looks more good
megapro is offline   Reply With Quote
Old 06-23-2013, 11:03 PM   #14
thought about making a tailgate/end panel
to tie both rear bedsides together...
maybe some tail lights then.
Honcho scrap blister pak bedsides... - Similar Threads
Stoked for bedsides! tozrovr Axial SCX-10 2 12-19-2011 04:26 PM
bedsides for the honch?? rc dreemer Axial SCX-10 4 11-12-2010 02:39 PM
scx10 Trail Honcho BEDSIDES! i wana make some! yellowpasta2000 Axial SCX-10 10 12-04-2009 10:53 PM
Bottoms Up ''Six-Pak'' chip cross Tires and Wheels 19 10-23-2009 11:02 AM
