06-24-2013, 08:00 PM | #1 |
Rock Crawler Join Date: May 2012 Location: Columbus
| traxxas shaft question
ive used the search button and found so many answers iv got a dingo and dont know what traxxas shafts will fit or yokes someone give me part numbers?? please and thanks dont like mips 8( |
06-24-2013, 08:44 PM | #2 |
Rock Stacker Join Date: Feb 2013 Location: greenville
Yea the traxxas slash shafts will fit but I used it in a pinch and it wasn't perfect but I'm sure with the correct yokes it would've been perfect but it did finish the day on the trail
06-24-2013, 09:31 PM | #3 |
Quarry Creeper Join Date: Mar 2013 Location: Moscow Russia
| Re: traxxas shaft question
E/T-Maxx shafts are heavy duty (part #1951 & 4928 ). They are thick and interfere with spur gear. Will need longer transmission output. Check CI upgrade kit. You can also harden your Axial WB8 shafts with 6mm links inside. Description on Axial web site. I did this to mine, still running. Last edited by nersik; 06-25-2013 at 12:29 PM. |
06-25-2013, 06:56 AM | #4 |
im using them on GCM transfer case so hopefully i wont need to spend much more
06-25-2013, 12:01 PM | #5 |
Pebble Pounder Join Date: Aug 2011 Location: Aiken
Take a look here http://crawlerinnovations.com/. You just need to drill the yokes out with a 5mm bit.
01-03-2014, 01:29 PM | #6 | |
RCC Addict Join Date: Jun 2013 Location: Port Saint Lucie, Florida
| Re: traxxas shaft question Quote:
Will be going to 3S power and a Holmes 35T Torque Master Pro next week, so we'll see how it holds up | |
01-03-2014, 01:43 PM | #7 |
| Re: traxxas shaft question |
traxxas shaft question - Similar Threads | ||||
bent motor shaft? traxxas vxl | brianw | Electronics | 11 | 09-26-2012 09:43 AM |
traxxas drive shaft swap question | idk | Venom Creeper | 9 | 01-07-2012 12:22 AM |
Traxxas shaft with metal U joint!!!How to? | macrawler | Newbie General | 21 | 12-31-2007 01:25 PM |
Traxxas half shaft question | Stallion1967 | Newbie General | 8 | 04-09-2007 08:49 AM |
