07-22-2013, 11:08 AM | #1 |
Rock Stacker Join Date: Jun 2013 Location: NE Ohio
| Waterproofing via Axial website?
Before I buy dialectic grease for the servo and balloons, does this method really work? Sent from my iPhone using Tapatalk 2 |
07-22-2013, 11:20 AM | #2 |
Quarry Creeper Join Date: Feb 2008 Location: stockton
| Re: Waterproofing via Axial website? |
07-22-2013, 12:00 PM | #3 |
Quarry Creeper Join Date: May 2010 Location: scotland
i wound`nt pout a balloon anywere near my esc as it cant get any air around it and the air in the balloon will just get hotter the more you run it
07-22-2013, 12:14 PM | #4 |
RCC Addict Join Date: Feb 2012 Location: UK
I intend to Plasti-dip mine. Even in this heat it never gets very hot on 2s even after a 5hr trail/crawl. If you are gonna get it wet to then that will cool it down. Hehe...
07-22-2013, 12:29 PM | #5 |
| Re: Waterproofing via Axial website? how much air flow you really think is getting to a crawlers esc? Many people plasi-dip just like my esc is and they still dont get hot.
07-22-2013, 12:37 PM | #6 | |
In the band for now. Join Date: Sep 2012 Location: roselle
| Re: Waterproofing via Axial website? Quote:
but in the end its still up to you on what to use. good luck on whatever route you take. | |
07-22-2013, 12:43 PM | #7 |
Rock Stacker Join Date: Apr 2013 Location: NW Washington
Have you ever tried the spray can plastidip?
07-22-2013, 12:52 PM | #8 |
07-22-2013, 12:54 PM | #9 |
Rock Crawler Join Date: Aug 2012 Location: 909 area
I used the balloon method hadn't had any problems
07-22-2013, 12:56 PM | #10 |
Rock Crawler Join Date: Oct 2011 Location: Lake Worth
People have said they need airflow but as crazy and crude as this looks this is what my Mamba Max Pro ESC was encased in and never got to hot or shut down even with a Tekin Pro4 3300KV on the other end. That was back then and now I will try Corrosion X but just thought I'd post this pic up. |
07-22-2013, 01:34 PM | #11 | |
if you balloon it then you have no air flow so the heat inside stay`s inside and just gets hotter the more you use it doesnt it or is there a secret window or something that let`s the air out | |
07-22-2013, 01:45 PM | #12 |
RCC Addict Join Date: Jun 2013 Location: Port Saint Lucie, Florida
A guy I met up with had his stock ESC in a baloon and it started to burn up (we could smell plastic burning) He's going to be plasti-dipping. I did mine in the dip and while ihavn't run through water yet, i do not smell burning and the fins are still exposed to the open air for cooling |
07-22-2013, 01:48 PM | #13 |
Bro your not hearing me. There is pretty much no air flow under the body on a crawler and if your ESC is getting hot at all you got problems. We arent talking about a E-Revo running on 6s, this is a crawler. Balloon up and move on, or plasti-dip and leave it like that. This is real easy guys and your over thinking it |
07-22-2013, 02:06 PM | #14 | |
now how`s does that make sense i dont understand as there is still no air flow for the esc so its going to heat up more than it would than being just under the body with air all round it | |
07-22-2013, 02:09 PM | #15 | |
Read what I wrote again. Never did I say the balloon is better. Your ESC is in a box you think its geatting air flow? Air touching it is not air flow Quote:
07-22-2013, 05:08 PM | #16 |
Pebble Pounder Join Date: Apr 2012 Location: Canada
I run my reciever box in a balloon with liquid electrical tape on the end and I used the liquid tape on my esc
07-22-2013, 06:02 PM | #17 |
Conformal coating makes the most sense to me. I'll keep my balloons for birthday parties.
07-25-2013, 06:19 AM | #18 |
Please forgive my ignorance on the subject. It sounds to me like Corrosion X or conformal coating and liquid tape is the way to go? I guess I'll just have to get over the fear of opening up my electronics! Sent from my iPhone using Tapatalk 2 |
07-25-2013, 06:29 AM | #19 |
the only "opening" you have to do is removing the plastic case from the ESC then dip it. I dipped the entire receiver also with the servo and esc connected so it's sealed as well |
07-25-2013, 06:40 AM | #20 |
| Re: Waterproofing via Axial website? Conformal coating is the only one of those three that was designed for waterproofing circuit boards.
Waterproofing via Axial website? - Similar Threads | ||||
Waterproofing Axial Wraith and SCX10 | blackn0va | Newbie General | 6 | 03-11-2012 07:45 PM |
Axial Scx10 parts website | buzzbe97 | Axial SCX-10 | 2 | 01-09-2011 05:40 PM |
AX-10 Kit removed from Axial Website | kurtz49 | Axial AX-10 Scorpion | 1 | 05-13-2010 01:29 PM |
waterproofing axial axles | kalin96 | Newbie General | 13 | 07-05-2009 12:11 AM |
axial website | tat2INDY | Chit Chat | 5 | 12-20-2007 04:42 PM |
