08-06-2013, 10:31 PM | #1 |
Pebble Pounder Join Date: Jan 2013 Location: Fortson
| My Suspension is Confusing Me-Need ideas
So my SCX currently has super soft springs all around, both upper and lower. My battery/electronics are all on the front of the truck but for some reason I'm not getting full flex on the front end. Without the shocks/springs on the truck the suspension isn't bound. I'm kinda at a loss because the rear end will articulate up to the bottom of the shock body with no problem and it has no weight over that end of the truck. My thought is I've gone to too soft of a spring up front and because of all the preload I have to run, it's more resistant than a stiffer spring that would be less into it's range of travel at the same ride height. Any ideas???
08-06-2013, 10:34 PM | #2 |
RCC Addict Join Date: Apr 2012 Location: Land of 10,000 Lakes
Is anything contacting the axle or servo? sent from my crappy phone using tapatalk 2 |
08-06-2013, 10:36 PM | #3 |
| Re: My Suspension is Confusing Me-Need ideas
Nothing appears or feels like it is.
08-06-2013, 11:06 PM | #4 |
Are your links contacting anything at full droop? Do you have cms? sent from my crappy phone using tapatalk 2 |
08-06-2013, 11:16 PM | #5 |
Links are not hitting anything and I do have CMS
08-06-2013, 11:42 PM | #6 |
Do you have a 3 link panhard set up, or 4 link? If you have panhard, check to make sure that is not binding, or contacting the pumpkin. Make sure the drag link and the and the panhard are parallel. Omg. When I said "if you have panhard" my phone auto corrected to pants... it's a good thing I caught that... sent from my crappy phone using tapatalk 2 |
08-07-2013, 08:34 AM | #7 |
Rock Crawler Join Date: Jul 2009 Location: Little Rock, Arkansas
Did you overfill the shocks? If they are filled to the max that could cause this. If you hold the front of the truck up so there is no load on it, but the wheels are all touching the ground, and then flex it, does it flex all the way? |
My Suspension is Confusing Me-Need ideas - Similar Threads | ||||
Traxxas TQ radio - confusing | TACORICAN | Newbie General | 14 | 03-08-2011 05:22 PM |
Suspension modification ideas. | thewayitis | Tamiya CR-01 | 1 | 01-26-2010 03:55 AM |
can any of you guys give me any good suspension ideas for my 09 comp rig? | blue bronco | Axial AX-10 Scorpion | 9 | 01-13-2009 09:55 PM |
suspension ideas, what do you think? | rockhound | Tamiya TLT Crawlers | 3 | 12-05-2004 09:12 PM |
