08-12-2013, 08:58 PM | #1 |
Quarry Creeper Join Date: Mar 2013 Location: Wisconsin
| 79scx10's extended cab 79 ford build |
08-13-2013, 01:18 PM | #2 |
| Re: 79scx10's extended cab 79 ford build
What's the wheel base for the 79 ford extended cab?
08-13-2013, 06:11 PM | #3 |
RCC Addict Join Date: Aug 2011 Location: round pond (aka clarksville TN)
| Re: 79scx10's extended cab 79 ford build |
08-13-2013, 06:28 PM | #4 |
Rock Crawler Join Date: Nov 2010 Location: roanoke
That is a nice truck!
08-13-2013, 07:18 PM | #5 |
| Re: 79scx10's extended cab 79 ford build Thanks! I always wanted to do a f250/f350 but I decided to do a extended cab 79 ford instead, it was a hard decision between your f250 bolt on truggy chassis and the extended cab
08-13-2013, 07:37 PM | #6 |
| Re: 79scx10's extended cab 79 ford build I thought it was 14", but I wanted to make sure
08-17-2013, 01:48 PM | #7 |
08-23-2013, 08:05 PM | #8 |
08-23-2013, 09:16 PM | #9 |
08-23-2013, 09:18 PM | #10 |
sorry for bad pictures
08-23-2013, 09:22 PM | #11 |
Rock Crawler Join Date: Jan 2013 Location: Laguna Niguel
Dude, your pics are great!
08-24-2013, 07:59 AM | #12 |
08-25-2013, 07:57 PM | #13 |
08-26-2013, 11:37 AM | #14 |
I've got a few questions, for the people with a extended cab 79 ford what drive shafts are you running and did you guys make your own links? Thanks |
08-27-2013, 07:53 AM | #15 |
Anybody?
08-27-2013, 06:51 PM | #16 |
Pebble Pounder Join Date: Sep 2010 Location: Lincoln
I pieced a couple of stock driveline's together for the rear. I'll try to get you some pics tonight. I think you might be able to get a long enough steel one from RC4WD.
08-27-2013, 07:21 PM | #17 |
I heard that they use wraith driveshafts, I don't know what to use. I'm hoping somebody will tell me what to use
09-03-2013, 07:38 PM | #18 |
Some parts came in the mail I know I'm not to the point where I need the wheels but I just couldn't pass up the deal, plus I can run them on my other 79 ford. I'm not to pleased with the axial tredpador tires that are on it. Last edited by 79SCX10; 09-03-2013 at 08:37 PM. |
11-05-2014, 08:06 PM | #19 |
Rock Crawler Join Date: Jun 2007 Location: Working in my dream RC workshop and remodeling my entire home.
This is great! I'm currently working on a Ford bodied scx "Mud truck". For the rear driveshaft, I used two female shafts with a male shaft in the middle, with one end glued in. My front is not as extended, and I'm using an extra CKRC driveshaft that I had used on my Wraith. Since the front is only extended a little, I used an aluminum spacer and some threaded rod to extend the four links. The rear links are made from 8-32 all thread, 1/4 inch brake line, and long Traxxas Revo rod ends made by RPM. I'm running 2.2 Eight-Shooter beadlocks and RC4WD Rock Crushers. I also swapped out the shocks with internal springed EMaxx shocks drooped. Keep up the good work! Getting there. Haven't changed out the rear stuff yet. Gonna work on that in a little bit. (Soon as wifey is tucked into bed) Only extended the front a little bit.... |
11-05-2014, 08:11 PM | #20 |
The thing that is giving me the most fits is the body mounts. This body is for a Savage XL and is pretty big. The stockers just aren't up to task. Plus, the front mounts would go through the windshield if I put them where they are intended to go. Keep up the good work! I wanna see how yours turns out!
79scx10's extended cab 79 ford build - Similar Threads | ||||
Micro Extended Cab Ford | wikedphil | Micro Scale Rigs | 24 | 02-26-2012 06:43 PM |
Tube Bed Ford F250 Extended Cab | scrapen | Axial SCX-10 | 37 | 10-20-2011 08:14 PM |
Ford extended cab playin' | badBKO | Scale Videos! | 2 | 03-18-2010 10:43 AM |
Ford extended cab mudder | badBKO | 2.2 Scale Rigs | 14 | 03-07-2010 03:34 PM |
ford f350 extended cab body | colorado_crawler | 1.9 Scale Rigs | 2 | 09-24-2009 08:39 AM |
