08-19-2013, 09:53 AM | #1 |
Newbie Join Date: May 2013 Location: Plymouth
| Wider Axles for SCX10
I'm sure this has been covered, but I've done a lot of searching and reading and haven;t found what I'm looking for... I want my scx10 Rubicon to have a wider stance for hopefully greater stability and less tipping. I'm also taking measure to lower COG and add some weight. The solutions I've seen so far - Vanuish OMF wheels and wide hubs - very cool but way expensive - gMade 15mm wideners - would need to drill out my wheels and the couldn't use stock hub covers - integy wider axle kit - heard they were junk What are other options? I need to research more but may adapt wraith axles? Thinking of trying to fab my own setup using the GMade parts as a starting point. Any other ideas? Trying to not spend a ton on this mod but want something sturdy and looks decent. Thanks in advance for any pointers and sorry if I just couldn't find the magic thread! |
08-19-2013, 09:56 AM | #2 |
| Re: Wider Axles for SCX10
I think the cheapest route is the GMade wideners. They work great for what they are. Wraith axles are a good solution. or There's also the scx - xr10 mod which will be in between Wraith and SCX10 axles... but it'll cost ya. or SCX10 axles with longer Beef Tubes. You'll need to be able to drill/tap your own holes... I think. |
08-19-2013, 10:47 AM | #3 |
RCC Addict Join Date: Jul 2008 Location: Fox Valley WI
A full wrap of lead tire weights on each wheel will add to traction and overall stability. Keeping the suspension and heavier components as low as possible helps greatly. I personally run the battery pack crossways on the chassis between the trans and front shock hoops to get that weight lower also. Hope this was helpful .
08-19-2013, 02:28 PM | #4 |
Rock Crawler Join Date: Jul 2011 Location: Placer County
^x2 on try to lower COG as much as possible and add weight down low before going all out and swapping axles or expensive mods. just weighting wheels, steel beef tubes, and weight distribution helped my rig a ton. also, widening the axles is going to take away from "scaleness" if it even matters to you.
08-19-2013, 03:34 PM | #5 |
Thanks folks - def working on the COG - have added some wheel weights but haven't had a chance to run with them yet. Have also considered lowering the battery - it's already up front but will try dropping it lower. Yeah - not going for anything expensive just yet - might try the gmades, but again hate to drill my wheels. As far as "scaleness" - I don't mind sacrificing a bit for performance - not competing or anything - just goofin' around with the kids! That said, I don't want anything too wacky looking or I'd go to another platform (and probably WILL check some other out when my wallet permits) Thanks again! |
08-21-2013, 12:20 AM | #6 |
Rock Stacker Join Date: Mar 2011 Location: sacramento
GMADE wideners i run the 13mm's and love how the perform.
08-21-2013, 06:27 AM | #7 |
StEvo - what wheels are you running? Did you need to mod them? I've got Axial 1.9 beadlocks... Thanks!
08-21-2013, 07:07 AM | #8 |
Don't Axial wheels have larger hub holes to accommodate that 2 tier hex hub? Anyway, if you do have to drill out the hub to fit the barrel nut, it won't be too much. You could still run them on the regular hub in a pinch. I run them on my 1.9 Mini and my foff truck. |
08-21-2013, 09:53 AM | #9 |
The narrow XR10 mod will add about 1/2" of width to the front axle. How to do the narrow XR10 mod to Axial axles Using wide beef tubes you could do the full width AXR10 mod and that will give you about 1.25" more width. Justin's "F-350 Truggy" (Rear Steer&AXR10 axles)... |
08-21-2013, 02:37 PM | #10 |
RCC Addict Join Date: Feb 2012 Location: UK
Mayhem Engineering do some nice wheels n wide hubs. Much cheaper than VP. I had the 1.9 Slamerz with .650 hubs. They widened the stance and did not need weighting at all. Made it a very stable rig.
08-22-2013, 08:05 AM | #11 |
Pebble Pounder Join Date: Mar 2013 Location: Honolulu
| Re: Wider Axles for SCX10 |
Wider Axles for SCX10 - Similar Threads | ||||
wider axles | tim the toolman | Formula Offroad | 2 | 03-11-2012 09:17 PM |
wider axles | buggy | General Scale Talk | 0 | 12-12-2010 05:18 PM |
wider axles? how to | BIGIN | Newbie General | 12 | 03-27-2007 10:47 AM |
Wider tf axles | skogsvild | Kyosho Crawlers | 1 | 04-03-2006 06:21 PM |
wider clod axles without wideners | jtothec | Tamiya Clod Buster | 14 | 01-07-2005 09:23 AM |
