08-25-2013, 06:29 PM | #1 |
Newbie Join Date: Apr 2012 Location: Farmington
| lift my honcho
the stock shocks are 80mm, if i put 90mm shocks on all corners will it lift my honcho? i know there are drop bracket lifts out there, but id rather do suspension.
08-25-2013, 07:33 PM | #2 |
I joined the Band! Join Date: Aug 2013 Location: The Hills Of VA
| Re: lift my honcho
Go with a shock around 100mm... Gives a nice lift..
08-26-2013, 01:59 PM | #3 |
| Re: lift my honcho
I use cheap butt Traxxas T-Maxx big bore plastic shocks. fairly inexpensive... seem to work good. Should be cheap to reseal if need be. I also use losi soft (white springs) Lift was actually minimal... as my shocks and springs offer a little static squat. This keeps ride height and the COG lower. But still offers good articulation from the 100 mm CO's You don't really want lift... you want max droop and compression. Longer then 100 mm... and you will likely need to offset the upper shock mount some. |
08-26-2013, 03:03 PM | #4 |
| Re: lift my honcho
agreed traxxas big bores 100mm , buy once and be done.
08-26-2013, 06:36 PM | #5 |
| Re: lift my honcho
thanks guys, im gettin KING shocks i really like them
08-26-2013, 06:38 PM | #6 | |
| Re: lift my honcho Quote:
08-26-2013, 09:26 PM | #7 |
Quarry Creeper Join Date: Mar 2013 Location: Moscow Russia
| Re: lift my honcho
Stock Axial SCX10 shocks are 90mm, not 80. You can get more articulation removing rubber dumpers from stock shocks. |
08-27-2013, 04:01 AM | #8 |
Newbie Join Date: Jun 2013 Location: Hawaii
| Re: lift my honcho |
lift my honcho - Similar Threads | ||||
Face lift for the Honcho!!! Pics! | DonnieB | 2.2 Scale Rigs | 4 | 05-23-2013 08:42 AM |
Honcho Lift Kit Questions... | Gimpdiggity | Axial SCX-10 | 11 | 07-03-2012 12:03 PM |
