09-26-2013, 09:53 PM | #1 |
Quarry Creeper Join Date: Sep 2013 Location: post falls
| advice for trail use Rubicon
I am going to build an scx10 Rubicon for trails just playing around, I'm going to run a brushed motor either from brood or HH and the HH esc, I will be running off of 2s lipo for now 3s soon, my question is what are the most common weak spots that show up with this type of use and what upgrades do I need?
09-26-2013, 10:20 PM | #2 |
Pebble Pounder Join Date: Aug 2013 Location: San Jose
I would suggest either upgraded center driveshafts or strengthen the stock ones. Also...to help with torque twist, I would mirror the transmission Sent from my SAMSUNG-SGH-I337 using Tapatalk 4 |
09-26-2013, 10:23 PM | #3 |
Quarry Creeper Join Date: Jul 2013 Location: Meridian
Welcome! I am in Idaho as well, do the same type of running, and asked a similiar question earlier. C hubs and knucles.... I kerp a few 3mm screws in my bag along with a small tool kit, a few wheel nuts, and zip ties. Where are you running? I am in Meridian area and travel with my rig to Asia.... |
09-26-2013, 10:30 PM | #4 |
Pebble Pounder Join Date: Mar 2013 Location: Chesapeake
Upgrade tranny gears. I prefer Robinson Racing gears. There are others out there but I run Robinson in all my vehicles and have not had any failures. Driveshafts will be your next weakest link. MIP and Junfac are the most popular. The next thing i did was installed the Hot Racing diff lockers in both front and rear axles. Again there are many to chose from. The Hot Racing were not my first choice but they were in stock and Robinson was gonne be awhile. It really just depends on what your trying to do. You can just fix stuff as it breaks or do some preventative upgrades. If your gonna run brushless up to 3s you will find your weak points really fast. Especially if ya run 2.2 Rc4wd Rock Crushers like i did on top of all that 2 and3s power. Tranny first though. Get the solid one piece output gear and the idler gear. Thats what failed me first. I wasn't even running lipo. Just them big arse tires and a 12t titan/xl5. Hope this helps. :thumbup: Sent from my VS840PP using Tapatalk 2 |
09-27-2013, 08:21 AM | #5 |
Rock Crawler Join Date: Jul 2009 Location: Little Rock, Arkansas
| Re: advice for trail use Rubicon
My best advice. Have fun with it and drive it. If something breaks, then upgrade it. Some parts may break for others and never break for you. I use my rig for trail use and some decently technical rock crawling and I have only ever broken 1 c-hub. That's it. My truck is freakishly strong. I would however recommend mirroring your transmission and upgrading to R2J's 4 link on your rear axle. Be sure to bring with you a a hex key or a hex screwdriver that fits your driveshafts' set screw because the driveshafts on these things can sometimes snag on a rock and pull off of the transmission output. You will simply have to place the driveshaft end back on the transmission output and retighten the driveshaft. Simple, but if you don't have anything to screw the set screw back in with, your run is over. |
09-27-2013, 08:45 PM | #6 | |
| Re: advice for trail use Rubicon Quote:
09-27-2013, 08:50 PM | #7 | |
09-27-2013, 08:51 PM | #8 | |
Your the second person to recommend mirroring the trans, how is this done? | |
09-27-2013, 09:12 PM | #9 | |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
I still have yet to make this change. I have to say I don't know how some of you break stuff so easily lol..I have yet to break anything and put my truck through a lot abuse. I only run the stock ESC with a mod 27t motor and a 2s lipo and its done every challenge ive thrown at it with no problems...Even having the tires lodged between rocks and straining the motor to get out...I guess in time ill break something but its been a tough cookie so far. I have upgraded but not due to breakage. Most will say run it till something breaks and that's what you need to upgrade. Last edited by 6sharky9; 09-27-2013 at 09:32 PM. | |
09-27-2013, 10:04 PM | #10 |
09-27-2013, 11:44 PM | #11 |
Easy way to know how to mirror the trans: Take apart the trans and upon reassembly, face 'axial' in on the motor plate towards the trans rather than out towards the spur gear. As for upgrades, well that can be a subjective thing in some aspects. I find it hard to run axles without beef tubes and at least aluminum chubs/knuckles/lockouts. Of course stronger servo, 32p gears, steel trans gears, drive shafts, hardened r/p and possibly wheels. Brushless can be waterproofed to work in a trail setting, unless you're submarining the thing. Its hard to point directly at what to upgrade first. With a lightweight stock-ish rig and easy trigger finger, one can go quite awhile without breaking much. |
09-28-2013, 12:14 AM | #12 |
Rock Crawler Join Date: Apr 2011 Location: British Columbia
I agree with those who wondered how people are breaking parts a lot, the first thing I broke was the outputs on the trans got chewed up and broke from the driveshafts popping off, however this happened on my 1.9 rig crawling indoor last winter against ax10's and a few xr10's so Robinson racing gears were my first upgraded then links, knuckles,a servo and then smoked 3 stock motors and bought a 35 turn h.h motor and a 5700 may 2s lipo and screwed around with tire choice's and finally like a week ago I got rear lockouts, I still run stock plastic driveshafts and I've seen several people break them quick but no issues here, we went out on Sunday and I was the only who didn't break and outclimbed 2.2 rigs, my trucks strength and durability surprise me
09-28-2013, 07:16 AM | #13 |
| Re: advice for trail use Rubicon |
09-28-2013, 07:19 AM | #14 | |
advice for trail use Rubicon - Similar Threads | ||||
TCS X-Trail Rubicon | Difuser | 2.2 Scale Rigs | 2 | 06-09-2008 11:49 PM |
first rig x-trail rubicon | gothikon | 2.2 Scale Rigs | 3 | 03-17-2008 07:35 AM |
Trail Run with K5 Blazer and Rubicon | Steveakus | Videos! | 7 | 12-24-2007 04:41 PM |
Boyer WK rubicon trail rig | HITMAN | HPI Wheely King | 31 | 07-22-2007 07:53 PM |
Wasted my steering at the Rubicon trail | str8axle | General Crawlers | 4 | 08-24-2006 10:28 PM |
