Gmade portals into a scx10 anyone try this? any pics? axles pretty strong? looks like you would get a ton more clearance thanks |
Re: Gmade portals into a scx10 I was having the same idea myself, I'm building a mudbogger Rubicon and the more clearance the better. |
Re: Gmade portals into a scx10 I had a set in my scx10 with a newbright jk body a few years ago, you get a bit more clearance under the diff, but they are wider than the scx10 diff's and to keep the whole thing looking right I had to drop the suspension down which gave it almost no uptravel. |
Re: Gmade portals into a scx10 Try doing a search there was over 10 rig done with this.I also did this but try buying a set of rims to fit was a pain in the a--. |
Re: Gmade portals into a scx10 Quote:
Re: Gmade portals into a scx10 a few things came up with a search but not much |
A mates Rig. http://www.rccrawler.com/forum/1-9-scale-rigs/450359-h2micr0s-scx10-fj40-trayback.html#post4372072 Sent from my GT-I9300 using Tapatalk 2 |
Re: Gmade portals into a scx10 3 Attachment(s) This has an scx front frame section in it and i had no problem with the install. |
Re: Gmade portals into a scx10 Nice but the gear reduction unit still is out in the open the rim should cover that up atleast. |
Re: Gmade portals into a scx10 |
Thats great but thats a 2.2 bigger rim and ring. |
Re: Gmade portals into a scx10 My post was for the OP. For the wheels you will need to use internal beadlocks to clear portals. You run into problem of inner ring. |
Re: Gmade portals into a scx10 Here is one I completed a few months ago. Pretty straightforward, watch pinion angle and use hardened steel drive shafts if your planning on brushless power. Feel free to ask any questions, I have a few build pics that may help. http://www.rccrawler.com/forum/axial...es-bronco.html |
