10-23-2013, 07:15 PM | #1 |
Newbie Join Date: Oct 2013 Location: Palmdale
| Need help
Hey There, I just received my new Jeep Rubicon RTR rig and I have a question; I would like to slow it down a bit, what gear do I replace and which one do i get?? I want it to crawl not be a speed demon. Any suggestion would be appreciated. I have not changed anything and I'm using the Axial radio with a 7.4 5000 mAh Lipo. Cheers, Rick |
10-23-2013, 07:47 PM | #2 |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
| Re: Need help
If you want to use the stock motor you have a couple of options. 1.) use a smaller tooth motor pinion gear...Your stock pinion should be a 20 tooth...You can go to a 16t pinion or maybe smaller..but always make sure your motor isn't getting to hot. 2.) You can use a larger spur gear..Your stock gear should be an 87 tooth...I would try a 90t with the stock 20t motor pinion..same effect but again watch motor temp. 3.) Your third option is to run a higher turn motor..Should you decide to do this you can try a 35 turn or even a 55 turn but go back to your stock gearing and start over watching your motor temps. Hope this helps. I recommend trying a 16 tooth motor pinion with the stock motor and spur gear...see how you like that and go from there. Last edited by 6sharky9; 10-23-2013 at 07:50 PM. |
10-23-2013, 08:17 PM | #3 |
| Re: Need help
Hey Thank you for your assistance.. This is very helpful. I think I will replace the pinion gear first as you suggested and go from there. Again...thank you Rick |
10-23-2013, 08:35 PM | #4 |
| Re: Need help
youre welcome
