11-12-2013, 09:25 PM | #1 |
Rock Crawler Join Date: Mar 2013 Location: columbus
| to much? Does this just seam like a little much ? Ok I have a donor Twin Hammers with the 2 speed trans. This is going in my next build. I will be building a truck and trailer to pull my other trail rigs. I know I need to pick up gears and replace the motor mount this is for mock up. I want to know what every one thinks. Build list Project (1972) big block. Axial dingo kit Aial lower Honcho links Axial bead lock wheels Axial light kit Axial Aluminum Knuckle Axial Aluminum C Hub Carrier Axial Alumimum Rear Axle Lockout MIP Spline Center CVD Kit SCX10 Pro Line Interco TSL SX Super Swamper 1.9 Tires Vaterra Slipper Spring Cup & Retainer Set Vaterra Aluminum Motor Plate & Clamp Team Losi 90T 48P Kevlar Spur Savox SA-1283SG Digital Steel Gear Servo Castle Creations 10 Amp BEC Castle Creations Mamba Monster 2 Brushless Esc/Motor combo Pro Line 1972 Chevy C10 Long Bed pick up body Vaterra 2 speed transmission with shift srvo and Receiver TrackStar 150A GenII 1/8th Sensored ESC Turnigy TrackStar Sensored Brushless Motor TrackStar Multi-Function Smart Program Box Rc 4wd Big dog trailer and Dinky hitch Used parts Honcho axles from cj Vanquish shock hoops Parts still needed at this point RC4WD Extreme Duty XVD Axles for SCX10 Total project finished $1,851.75 Last edited by greengoblin; 05-24-2014 at 06:04 PM. |
11-13-2013, 01:31 PM | #2 |
Rock Crawler Join Date: Jul 2011 Location: Placer County
| Re: to much?
Not if everything else is built to handle that power. Many on here put ridiculous power through their rigs. Whether or not a narrow track width scx10 can be stable with all that power at speed is another topic ;) |
11-13-2013, 02:29 PM | #3 |
Rock Stacker Join Date: Aug 2013 Location: St. Louis
| Re: to much?
Actually the 2 speed makes it much more drivable. RC4WD 2 speed w/ a 4000kv 4 pole. Rest of the truck needs to be up to the challenge though.
11-13-2013, 02:40 PM | #4 |
Rock Crawler Join Date: Jan 2012 Location: Mcallen, Tx
| Re: to much?
sweeeeet jeebus.. |
11-14-2013, 08:36 AM | #5 |
Rock Stacker Join Date: May 2013 Location: Phenix city
| Re: to much?
That truck going to be like aaaaaahhhhhhhhh
11-14-2013, 09:30 AM | #6 |
| Re: to much? |
11-19-2013, 09:44 PM | #7 |
| Re: to much? I dont know if im going to do a build thread on this rig or not. Im still getting the parts together for this build. This is a few photos of the mount i made for the transmission to fit in the scx10 frame. |
11-19-2013, 10:23 PM | #8 |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
| Re: to much?
Why have the motor mounted so high?
11-20-2013, 11:05 AM | #9 |
Quarry Creeper Join Date: Sep 2005 Location: LRAFB
| Re: to much?
big block
11-20-2013, 12:59 PM | #10 |
| Re: to much? |
11-20-2013, 01:08 PM | #11 |
| Re: to much?
lol..ok.i walked right into that one; but still looks like it might be top heavy
11-20-2013, 07:22 PM | #12 |
| Re: to much? I mounted the transmission on its side like this so I can run 2 batterys. If at any time I want to run a stock motor and transmission set up its just 4 screws and it pulls out. |
11-20-2013, 07:28 PM | #13 |
| Re: to much? |
11-20-2013, 07:35 PM | #14 |
| Re: to much? From a performance point of view you may find yourself doing that in the future..Dont Underestimate the power of a well built small Block |
11-20-2013, 07:51 PM | #15 |
11-20-2013, 07:51 PM | #16 |
Pebble Pounder Join Date: Nov 2010 Location: 419 area
| Re: to much?
I love the idea! but have you thought about how much torque twist it may have?
11-20-2013, 08:18 PM | #17 |
| Re: to much? |
11-20-2013, 08:18 PM | #18 |
| Re: to much? New parts are in for the transmission repairs. New slipper spring kit. New motor mount kit. New R.p.p. pinion. New Losi kevlar spur gear. I also lubed the trans while it was apart. |
11-20-2013, 08:24 PM | #19 |
| Re: to much? |
11-20-2013, 08:24 PM | #20 |
| Re: to much?
the man is a artiest let him work this thing is going to be a trailer hauler that is going to pulling his other rigs around
