12-03-2013, 08:32 AM | #1 |
Newbie Join Date: Aug 2010 Location: Menominee
| Stuck Grub Screws in SCX10 Dingo
I am doing my winter upgrades, I really haven't changed much on my Dingo, but this year I got some 1.9 Baja Claw TTC's, Gear Head Alu wheels, Vanquish 4 link set a nice aluminum front Bumper and winch, chassis mount servo and some King Shocks, I also got some nice hardened steel drive shafts and I have run into the issue of VERY stuck grub screws, I cannot budge them, even after 2 weeks soaked in Kroil, any advice? I am worried they are starting to get stripped. Any advice?
12-03-2013, 08:41 AM | #2 |
I wanna be Dave Join Date: Aug 2007 Location: JERSEY BOONDOCKS
| Re: Stuck Grub Screws in SCX10 Dingo
If you don't plan on using the existing driveshafts again, just drill them out.
12-03-2013, 09:05 AM | #3 |
Yah, I suppose, I kind of wanted to save them, but if I have to I have to I guess.
12-03-2013, 09:38 AM | #4 |
A bit of heat from a soldering iron will do the trick if you loctited the screw in place. Run a thin cut off wheel across the screw to create a slot for a screwdriver if the hex strips. The heat from the cut usually frees things nicely.
12-03-2013, 01:03 PM | #5 |
I will give that a try, thanks!
12-03-2013, 02:08 PM | #6 |
| Re: Stuck Grub Screws in SCX10 Dingo This x2. I have a cheap soldering station with a pointy tip just for freeing up loctite. If you are going to use your good iron, at least put a junk tip in it first.
12-03-2013, 02:54 PM | #7 |
On a totally unrelated note Menominee has THE coolest rest area I've ever been to in the US. Damned taj mahal with a foyer full of vending machines and kiosks it was insane. |
Stuck Grub Screws in SCX10 Dingo - Similar Threads | ||||
help needed, screws stuck and stripping out | James003 | Tires and Wheels | 11 | 08-23-2010 03:02 PM |
Anyone replace all the phillips screws with hex heads on their SCX10? | BigB_117 | Axial SCX-10 | 11 | 06-28-2009 11:04 AM |
X-Factor axle shaft grub screws | amstel78 | XTM Crawler | 3 | 09-27-2008 03:54 PM |
Grub Screws | BrockGrimes | Tamiya TLT Crawlers | 0 | 03-10-2007 03:27 PM |
