Thread: "Roller" won't roll?!?
Old 06-20-2015, 02:53 AM   #1
Default "Roller" won't roll?!?
Hey guys. I'm new to RC and to RCCrawler, as such move this to the newbie section if it doesn't belong here (I wasn't sure where to put it).
Got my first RC (SCX10 Wrangler G6 Kit) - just spent 7 hours building and should be in the roller stage. I haven't purchased any electronics yet.
When I push it, it'll roll about 6 inches and then it locks up...it will then roll backwards 6 inches back to its starting point and lock up again. Is my slipper clutch not set right? Or did I screw something else up? Please help give me a starting point for troubleshooting.
TagRC is offline   Reply With Quote
Old 06-20-2015, 03:28 AM   #2
Default Re: "Roller" won't roll?!?
Disconnect one driveshaft and try again...if it still does it then disconnect the other...if it still does it then it has to be in one of the differentials...pick one end off the table and try again....just like the driveshafts...that should narrow it down..could be the gears in the differentials have some residual flashing on them..could also be in the trans gears if it rolls fine with the driveshafts removed...coukd also be a bearing issue although its not as likely
allanon1965 is offline   Reply With Quote
Old 06-20-2015, 07:08 AM   #3
Good diag tip above.
I'm willing to bet it's friction in one or both differentials. Make sure the pinion gears are seated well and when you spin them (meshing with the ring gear), they're nice and free.
And definitely double check that your driveshafts are phased properly (pins at each end face the same way)
GodSpeed999 is offline   Reply With Quote
Old 06-20-2015, 07:21 AM   #4
Driveshaft phasing is my first thought, easiest thing to fix too.
forty2 is offline   Reply With Quote
Old 06-20-2015, 08:02 AM   #5
Thank you all for the help. I followed the above steps and discovered it was my fault. I had the wrong length grub screw holding the driveshaft to the transmission on the side of the spur gear cover and it was hitting the cover. It's all fixed up and rolling now...
I did notice while I had it apart though that some of the teeth on the plastic gears in the transmission seem a bit out of whack. Doesn't look like they are going to last too long so I'll order the metal ones right away so they are on hand when the plastic ones fail.
Thanks again!
Old 06-20-2015, 08:03 AM   #6
Oh, and when you guys say "driveshaft phasing" are you referring to the lines on each half of the shaft matching up when you put them together?
Old 06-20-2015, 10:16 AM   #7
Check the set screw for the rear driveshaft at the trans. I had the same issue and found the screw can go into far and contact spur gear back plate.
guido5526 is offline   Reply With Quote
Old 06-20-2015, 10:33 AM   #8
I joined the Band!
Yes, but also when you assemble the locker in the transmission. The holes for the screw pins holding the driveshaft should line up.
Eric0424 is offline   Reply With Quote
Old 06-20-2015, 11:42 AM   #9
check your pinion angles on the drive shafts they might be binding
duellym is offline   Reply With Quote
Old 06-20-2015, 12:04 PM   #10
I joined the Band!
Read post #5.
Old 06-20-2015, 12:50 PM   #11
oh i didn't see that
"Roller" won't roll?!? - Similar Threads
<iframe width="420" height="315" src="//www.youtube.com/embed/gYr-dbPEOnE" frameborde boolean21 Scale Videos! 0 10-01-2013 09:39 AM
School me on the drag brake or what does Axial use for "roll control" LowLock Axial AX-10 Scorpion 9 04-27-2011 11:37 PM
