12-14-2013, 07:20 AM | #1 |
RCC Addict Join Date: Feb 2012 Location: UK
| Axial-exo-steel-spur-gear-32p-54t fit the SCX10?
Hello. I was hoping to be able to fit some 32p steel gears for durability. Would this work? Kind regards |
12-14-2013, 07:30 AM | #2 |
Thanks. Will the EXO one fit. Looks a little different in the pic. I won't it ideally to just bolt on and go. :-)
12-14-2013, 07:31 AM | #3 | |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
| Re: Axial-exo-steel-spur-gear-32p-54t fit the SCX10? Quote:
I can understand maybe needing or wanting steel gears but why that ratio...what are you using to power it and using it for ? | |
12-14-2013, 07:40 AM | #4 |
The Axial Exo Spur gears are made to fit on the case of the center differential in the Exo, not the SCX10 transmission. With 32P gears plastic will probably be strong enough. You can use the DuraTrax 32P 56T Nitro Evader BX spur. The part# is DTXC9397. If you want steel, then the RPP Robinson Racing 32P Slipper Kit Steel Slipper(56T) Part# RRP7856 and the Beefy Top Shaft from Supershafty will work. Transmissions - Super Shafty |
12-14-2013, 08:10 AM | #5 |
Thanks folks. Much appreciated.
12-14-2013, 08:59 AM | #6 |
| Re: Axial-exo-steel-spur-gear-32p-54t fit the SCX10? |
Axial-exo-steel-spur-gear-32p-54t fit the SCX10? - Similar Threads | ||||
looking for a 32p Hardened Steel spur to fit an axial scx10 | moza | General Crawlers | 2 | 03-28-2012 05:45 AM |
Wraith Spur gear Cover.. Won't fit my SCX10 | madkawi650 | Axial AX-10 Scorpion | 2 | 09-24-2011 05:12 AM |
