12-18-2013, 06:19 PM | #1 |
Newbie Join Date: Nov 2013 Location: under the sun
| G6
Well I am new here and had a question for you guys. Has anyone had a problem with your scx10 kit axles not turning smoothly? The reason im asking is my new g6 came in the other day. I put it together following the directions to a "T" and the axles sound like crap. I tried taking apart cleaning everything, re- greasing, and reassembling and no luck. Any ideas to what may be causing this. side note: Ive already called axial and they are sending me just the plastic axle housings |
12-18-2013, 06:29 PM | #2 |
| Re: G6
Maybe try re-seating the bearings and/or try to remove the possible burr from the bearing seats. Things are not perfect sometimes. Good on axial to send out some new plastic.
12-18-2013, 07:18 PM | #3 |
| Re: G6
Okay ill try the re seating and the removing of the burrs if any process. thanks for the fast reply
12-18-2013, 07:38 PM | #4 |
Quarry Creeper Join Date: Nov 2012 Location: spanish fork
Maybe, last kit I built the ring and pinion wouldn't sit right, the pinion wouldn't go in all the way with out a oober ton of pursue. It wouldn't stick out of the housing far enough to get the drive shaft to bolt up to the pinion shaft...if that makes sense Sent from my VS980 4G using Tapatalk |
12-19-2013, 01:44 AM | #5 |
Newbie Join Date: Jan 2012 Location: Northpole
| Re: G6
I buffed my gears with a wire wheel brush for my demal tool. Makes them smooth and cleans off any casting flaws. But for sure check the bearing seating.
12-19-2013, 07:58 AM | #6 |
| Re: G6
Okay. removed bearings, looked and cleaned up any imperfections, and reseated bearings and still no good. I will have to go pick a wire wheel to see if that will help. Thanks guys i really appreciate the help.. |
12-19-2013, 08:12 AM | #7 |
Rock Stacker Join Date: Dec 2012 Location: USA
| Re: G6
I don't have a G6 but I did build a Rubicon kit and had a similar problem when it seemed like I overtightened the screws holding the two axle housing halves together.
12-19-2013, 01:17 PM | #8 |
| Re: G6 |
