Thread: Will the proline TSL sx "super-swampers" XL work??
Old 12-20-2013, 04:15 PM   #1
Talking Will the proline TSL sx "super-swampers" XL work??
Hello,
I didn't know where to put this thread so this will do. But anyways I need to here some suggestions on these Pro-line TSL sx super-swampers XL, these are the newer ones (at least to me) here are the dimensions:
Height: 4.75 in'
Width: 1.75 in'
I would mount these to the axial 1.9 beadlocks, I think this will work because there offset is different and from experience with these wheels they won't touch the shocks im running. These will be mounted on the jeep scx10 rtr, now I know the rtr is an older truck but i would like to mount these tires on there so if anyone can tell me if Im doing it right or not, thank you - axial 4x4 crawler.
axial 4x4 crawler is offline   Reply With Quote
Old 12-20-2013, 04:55 PM   #2
Default Re: Will the proline TSL sx "super-swampers" XL work??
The wheels and tires section would work too
The older shorter versions worked well and I dig the 2.2's, a buddy now swears by the newer xl 1.9's. Get some good foams to go along with them and you're golden.
Meatwad is offline   Reply With Quote
Old 12-20-2013, 05:01 PM   #3
Thank you, I tried putting 2.2 super-swampers on there and they are quite large but I was using my honcho to mount just to seeing if they fit. But I also saw the 2.2 mud-slingers, they are not to much bigger and they have some insane treads on them, but I will have to mess around with the shocks so they don't rub but I doubt it with the wheels offset. Im only worried about the servo not be able to turn them, what do you think about the mudslingers? thanks - axial 4x4 crawler
Old 12-20-2013, 09:22 PM   #4
I'm running 2.2 swampers on wraith axles, agreed they're big for scx10 width. Haven't tried my set of mudslingers yet, been happy with the swampers.
Old 12-20-2013, 09:27 PM   #5
The jeep isn't old. Anyways yes they will fit. I just got a JK kit and put some XL's on it. They are about the same size as the stock tires just wider. I would recommend some Crawler innovations foams with them. The foams that come with the XL's are unreal they are 2x the size if the actual tire.
fr8cture is offline   Reply With Quote
Old 12-21-2013, 12:08 AM   #6
i have ran both the shorter tsl and the xl and mud slinggers and all of them work great.. wit the XL's tho i had to run the wider hex's in front to clear my steering bc of my wheel offset
CamposZac96x is offline   Reply With Quote
Old 12-21-2013, 03:33 AM   #7
Here's a pic of some 1.9 SX XL's on Axial beadlocks with 3 oz in each tire, work great for me.
Nix951980 is offline   Reply With Quote
Old 12-21-2013, 08:04 AM   #8
Which wheels did you use?
Road1will is offline   Reply With Quote
Old 12-21-2013, 08:23 AM   #9
raceeng18 is offline   Reply With Quote
Old 12-21-2013, 08:33 AM   #10
I run the xl, s on tss wheels, they are a great tire. But you will have rubbing issuse on a stock scx. My wheel wells are cut on my honcho.
And just a heads up, there is a lot of pics and info as stated in wheels section. There is a whole thread or two about the xl, s
fj40jay is offline   Reply With Quote
Old 12-21-2013, 06:37 PM   #11
Axial beadlock with gear head rings and lockedup rc hardware.
Old 12-22-2013, 03:15 PM   #12
Oh great guys thanks for the input, I was a little busy and couldn't get to the forums. But I think the XL's will work, the only problem is im kinda out of money for know since I just bought a erevo, and a ridgecrest its cost me grief but its either the 2.2 mudslingers or the XL's which both are nice just depends on which I get. Thanks again guys - axial 4x4 crawler
Old 12-22-2013, 03:16 PM   #13
Originally Posted by raceeng18 View Post
Thats a nice jeep you have, thanks for the example I appreciate it - axial 4x4 crawler
Old 12-22-2013, 03:18 PM   #14
Yes your right, I just didn't think at first but thank you for the input - axial 4x4 crawler
Old 04-01-2015, 06:23 AM   #15
Did you need to get wider hex or did the xl super swampers fit straight on without any probs?
Niko_RcCrawler is offline   Reply With Quote
Old 04-01-2015, 09:38 PM   #16
I used the stock hex, worked fine.
