12-31-2013, 10:37 PM | #1 |
Rock Stacker Join Date: Feb 2013 Location: Asheville
| 3 Link Keeps coming loose
Just got my SCX10 Rubicon Unlimited and after about 10 mins the front 3 link came out from the mount under the servo plate. I was able to just pop it back in but...couple mins later of running and it popped out. Is there a washer or something that the factory forgot to hold it in it's mounting hole? |
12-31-2013, 11:19 PM | #2 | |
Quarry Creeper Join Date: Dec 2012 Location: Seattle
| Re: 3 Link Keeps coming loose Quote:
http://www.vanquishproducts.com/axscx3licmsp.html Works great, will solve your problem! | |
12-31-2013, 11:30 PM | #3 |
Rock Crawler Join Date: Aug 2010 Location: Esko
I belive there is all the parts needed in the parts bag to convert it to 4 link. That would also solve your problem for free. Sent from my SAMSUNG-SM-N900A using Tapatalk |
12-31-2013, 11:40 PM | #4 |
Rock Crawler Join Date: Feb 2012 Location: Tennessee
If you want to keep the 3 link just stick a washer on the end that wont pull through the hole.
01-01-2014, 01:16 AM | #5 |
Thnx for all the info, think im going to 4 link it from the parts tree, just need to get a screw and nut to attach the fronts to the truss. My first scale rig, was a little shock at all the parts in such a tight space. |
01-01-2014, 01:46 AM | #6 | |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
4 linking is the best fix..go for it Hardware store should have a 3mm screw and lock nut to install it...Your left however with 2 smaller screws you need to mount the ends..They are really small button head screws and very short..Those might be hard to find at a hardware store...I just cut those extension arms off and filled in the mounting holes with silicone so you don't get water in them From this To this. Last edited by 6sharky9; 01-01-2014 at 01:52 AM. | |
01-01-2014, 10:46 AM | #7 |
I was able to mount the truss with the 2 screws that were running through the top of the diff previously. I don't have screws(RTR didn't come with any, forgot to buy a bundle at the LHS) to attach the extension arms but it seemed sturdy with out extensions screwed in, Ill just silicone the holes like you said. |
01-01-2014, 10:54 AM | #8 |
Newbie Join Date: Dec 2013 Location: Alpharetta
I had the same issue...bought the vanquish kit linked above and no more problems, and no more wobbly axles.
01-01-2014, 11:07 AM | #9 |
My wallets hurting to bad from the purchase of the truck to get anything besides batteries right now...
01-01-2014, 03:20 PM | #10 |
Lowes had a 4-40 screw and locking nut that worked added a dab of thread lock just to be sure. Ran it for bout 45 mins did really well. Time to relocate the battery to the front and then take her to the trails in the next couple days and see what it can do. |
3 Link Keeps coming loose - Similar Threads | ||||
Lights keep coming loose | mud-sweat-gears | General Scale Talk | 2 | 11-18-2010 04:40 AM |
Wheels Coming loose | GrapeApe | EnRoute Berg | 10 | 12-06-2009 06:23 AM |
slipper clutch coming loose | BEN214 | Axial AX-10 Scorpion | 4 | 03-12-2009 07:31 AM |
AX10 driveshafts coming loose | 75fan | Axial AX-10 Scorpion | 16 | 02-17-2009 06:34 PM |
slipper clutch keeps coming loose | Boos Boy | Axial AX-10 Scorpion | 2 | 06-20-2008 12:44 PM |
