01-07-2014, 05:23 PM | #1 |
Mip scx10 driveshafts say they are not compatible with the rubicon...anybody using hardened shafts and what kind?
01-07-2014, 07:17 PM | #2 |
Pebble Pounder Join Date: Oct 2013 Location: Stockton
| Re: rubicon steel driveshafts
It's my understanding that both MIP and Junfac will fit.I run Junfac myself
01-07-2014, 07:24 PM | #3 |
Which junfac u run?
01-08-2014, 06:23 AM | #4 |
Quarry Creeper Join Date: Jul 2013 Location: Toronto
I used the MIP kit 10145 see my thread here --> MIP Driveshaft you will run into some issues but it can be resolved MIP now makes a kit specifically for the SCX10's with the WB8 driveshafts, the kit # is 13360 Axial 1:10 SCX10 Kits #AX90022, #AX90027, #AX90028, #AX90034 | Page 1 of 1 |
01-08-2014, 07:34 AM | #5 |
thanks for the info.
01-08-2014, 07:42 AM | #6 |
Pebble Pounder Join Date: Jan 2014 Location: Adelaide
The honcho and the rubicon are the same WB so these should fit Junfac Honcho Drive shaft Last edited by pickled; 01-08-2014 at 07:46 AM. |
01-08-2014, 07:46 AM | #7 |
| Re: rubicon steel driveshafts |
01-08-2014, 07:47 AM | #8 |
i seen that as well, but something about the design concerns me, it looks like there are rings holding the cross pins in the shafts, is that a metal ring or a rubber o-ring and how durable is the ring if something hits it while the shaft is spinning?
01-08-2014, 07:51 AM | #9 |
It's a metal snap ring.The kit came with extra ones.I thought about putting some heat shrink tube over them to help keep them in place
01-08-2014, 10:13 AM | #10 |
Thanks for the reply
01-08-2014, 10:23 AM | #11 |
| Re: rubicon steel driveshafts I ran junfacs on my wraith till I broke them and upgraded to MIPS. I had the rocks peel those rings out of their groove a couple times. There is also a set screw like mip has but the pin doesn't have a flat for the set screw to engage like mip does. They also don't slide in themselves very well when they have torque applied. The upside is that they are way lighter than MIPS.
01-08-2014, 01:48 PM | #12 |
Thanks for letting me know..i will mod the originals and save up for the MIP set
01-08-2014, 06:10 PM | #13 |
Pebble Pounder Join Date: Dec 2013 Location: MARIETTA
I run the MIP shafts on my Rubicon and had no issues ,swhatsoever. The wheelbase is the same as Honcho so i don't see what the issue would be.
rubicon steel driveshafts - Similar Threads | ||||
building steel driveshafts | stanmondz | Axial SCX-10 | 14 | 09-20-2012 02:36 PM |
Steel driveshafts w/pics | Reflection | General Crawlers | 7 | 11-15-2004 06:31 PM |
