Thread: Dingo Kit Body Painting Question?
Old 01-11-2014, 07:50 PM   #1
Default Dingo Kit Body Painting Question?
Do you guys trim the body first or paint first? I was going to rough the inside with fine sand paper but when I tested it on a small scrap piece it seems like it would leave scratch marks or will the pain fill them in and hide them? By the way this is my first kit, and first time painting. Thank for any tips.
Boats85 is offline   Reply With Quote
Old 01-11-2014, 07:56 PM   #2
Default Re: Dingo Kit Body Painting Question?
You cut the body before it is painted so that you can see the cut lines. It also makes marking the location of the body post holes a lot easier since you can see the body posts when you put the body on the chassis.
k7zpj is offline   Reply With Quote
Old 01-11-2014, 08:03 PM   #3
Thanks!!!
Old 01-12-2014, 12:28 AM   #4
Don't use sand paper on the inside use a scourer from your sink
pickled is offline   Reply With Quote
Old 01-12-2014, 10:14 AM   #5
I like to use #000 synthetic steel wool to scratch up the inside, works really well.
2JSC is offline   Reply With Quote
Dingo Kit Body Painting Question? - Similar Threads
Dingo Kit Headlight question JackDawack Axial SCX-10 12 05-22-2012 09:24 PM
Dingo Kit Bearing Question. xCarbonx Axial SCX-10 0 05-02-2012 07:25 PM
Question on painting a body? calyakker Paint and Body 7 01-31-2007 06:20 PM
Body painting question 01XJ Newbie General 2 07-08-2006 10:50 AM
