Thread: Best Drive Shafts Available
Old 01-11-2014, 02:15 PM   #1
Thumbs up Best Drive Shafts Available
ive done some digging and i cant find a solid drive shaft thread for the scx10....i know there are many companies making drive shafts but im unsure on what everyone is running....ive got the stock W8 honcho shafts and theyve seen many miles...ive bought a few rebuild kits and even wrapped the barrel in tin foil to elminate the clicking...but of course that wears out and the shafts have play again....so my question is...whats everyone running? whats everyone happy with? i bet the first comment will be MIP BUT! can i run MIPs with the gear cover?? Im interested in the RC4WD punisher....Gmade Shafts...ETC...whats your thoughts!
MichianaRCcrawlers is offline   Reply With Quote
Old 01-11-2014, 02:28 PM   #2
Mip now makes a shaft that doesnt rub the cover....sorry i dont have the part number off the top of my head...
allanon1965 is offline   Reply With Quote
Old 01-11-2014, 02:46 PM   #3
Default Re: Best Drive Shafts Available
Junfac
Johnnysplits is offline   Reply With Quote
Old 01-11-2014, 02:58 PM   #4
MIP #13360 That's all you need.
Billy D is offline   Reply With Quote
Old 01-11-2014, 04:19 PM   #5
Mmm no if you have a Trail Honcho or Rubicon Jeep (ie. longer wheel base).
MIP #11116 comes with 3mm bolt-thru pins like the Axial Wild Boars.
Some of the MIP stuff comes with 4mm scrub screw "design" for ye olde pre-bolt-thru outputs. Found this the hard way.
You also need MIP #11117 if you're running the spur gear cover (comes with the #11116, but for other kits with shorter hubs.)
Ambis is offline   Reply With Quote
Old 01-11-2014, 05:40 PM   #6
MIP #13360 work with all the newer trucks with 12.3 wb
COMPATIBILITY:
SCX10™ Trail Honcho RTR - AX90022, SCX10™ Jeep Wrangler Unlimited Rubicon Kit and RTR – AX90027 & AX90028. SCX10 Jeep Wranger G6 Kit - AX90034. Does not fit the SCX10™ Dingo Kit!!
I took this from the website.
Geeoff is offline   Reply With Quote
Old 01-11-2014, 05:57 PM   #7
Originally Posted by Johnnysplits View Post
Junfac
Calderwood is offline   Reply With Quote
Old 01-11-2014, 07:14 PM   #8
Enlighten me on Junfacs....is he serious or just being funny...those MIPs seem to be a buy it once and it lasts forever!
Old 01-11-2014, 07:21 PM   #9
Either maxx shafts or mip's.. there are no others.
Originally Posted by Ambis View Post
Mmm no if you have a Train Honcho or Rubicon Jeep (ie. longer wheel base).
This is what you use with the older hubs for thru hole stuff. Either way trying to break loose an m4 set screw/screw pin is alot easier than an m3...
Meatwad is offline   Reply With Quote
Old 01-11-2014, 07:39 PM   #10
MIP's all the way! It's the only drive shafts I'll run on my trucks.
DIRTSLINGER is offline   Reply With Quote
Old 01-11-2014, 07:40 PM   #11
the #11117 is simply an extension to clear the cover i take it...im guessing the #13360 is simply the 11116 with the extension?
Old 01-11-2014, 08:08 PM   #12
Junfacs are a joke!!
ZippoMan is offline   Reply With Quote
Old 01-11-2014, 10:25 PM   #13
I almost bought junfacs. They were on back order so I cancelled my order and picked up some MIP's. I am happy with my decision
Tom95YJ is offline   Reply With Quote
Old 01-11-2014, 11:35 PM   #14
I ran Punishers for three years, didn't break but really worn out and now I replaced them with MIP and a 7" Punisher in the rear.
arctichorse is offline   Reply With Quote
Old 01-11-2014, 11:49 PM   #15
Yup easy answer is MIP's. Tough as nails and available in so many different variations the sky is the limit on how many ways you can mix parts and pieces.
Oddly enough t maxx shafts do work well if you have the newer trans outputs and pinion inputs to run them.
WHITE-TRASH is offline   Reply With Quote
Old 01-12-2014, 12:07 AM   #16
Maxx shafts, cheap too.
2JSC is offline   Reply With Quote
Old 01-12-2014, 05:39 AM   #17
Best mod I have done, bulletproof!
NFA Fabrication is offline   Reply With Quote
Old 01-12-2014, 06:15 AM   #18
I see a few laughing at my Junfac suggestion, yet they don't explain their experience with them. I've used them in one build with no issue, but someone on RCC has brought a design flaw to my attention that I never gave any thought to. There are circular snap rings that hold the cvd pins in place that can get ground up and pop off, letting the pin fall out while traversing rocks. I've never had a problem because I don't have those kind of rocks to drive over. So if you do, forgive my suggestion as the problem that I mentioned will happen to you eventually.
Old 01-12-2014, 08:34 AM   #19
I also run MIP,s, but I do know a few very experienced guys that swear by the Junfac shafts.
fj40jay is offline   Reply With Quote
Old 01-12-2014, 08:51 AM   #20
only 3 years!!?? that seems good to me! i get 3 months topps from the stock W8s id be pleased with 3 years...do you remember what length you purchased? RC4WD have MM lengths and in only own a tape measure lmao
Junfac ones seem to have a good price compared to the #133360 MIPs id have to buy at $75 + shipping....since im only in the rocks 30-40% of the time since im on trials 70%.......it good to keep my options open
Best Drive Shafts Available - Similar Threads
Creeper Drive Shafts/Stub Shafts boog1313 Venom Creeper 3 04-23-2011 09:32 AM
AX10 MIP C Drive dig drive shafts in stock! RPP Hobby RPP Hobby 1 12-03-2009 10:50 PM
