02-08-2014, 01:49 PM | #1 |
Rock Crawler Join Date: May 2013 Location: Somewhere in space
| Loud sound coming from rear axle?? Help!!!!
So I have a the J/K rtr and I already waterproofed the truck but know my rear axle makes a loud ticking sound when I hold it up and test it. I put a lot of marine grease in both axles and I even pealed the seals of the bearings to put marine grease inside of them so they don't rust. I haven't driven the truck much and if you hold the rear axle you can feel vibration and that's not normal! So any suggestions on what it could be? I have taken the axle apart two times to make sure the gear mesh isn't tight and the gears appear to be okay. Here's all the mods I've done just in case your wondering: - mirrored the transmission - 4-linked front - axial aluminum links uppers, lowers, and front steering links. - 1.9 super swampers on rc4wd rims (these came off my honcho, so there used.lol.) - 110 mm King shocks w/ reservoirs (yes I know there to large but there the only ones I could get). -level 3 racing droop kit - moved the battery location horizontal on the frame (zip tied to the shock hoops) - moved receiver box to the rear (zip tied to the rear shock hoops and frame) - plasti dipped esc, servo and I double Balloned them plus the receiver. This set-up seems to be great even with my gopro mounted on the cage with the custom mount I made. So the mods go on and on but I need to know about my axle. Oh I almost forgot, the driveshaft angle is okay, that's why I got the droop kit for the insane large shocks and I'm working on getting more articulation ( all I have to do is change shock mounting positions). Sorry its a large thread, I would apperciate any help - axial 4x4 crawler |
02-08-2014, 02:04 PM | #2 |
Rock Crawler Join Date: Oct 2012 Location: Casper
| Re: Loud sound coming from rear axle?? Help!!!!
Is your driveshaft aligned, correctly?
02-08-2014, 02:07 PM | #3 |
| Re: Loud sound coming from rear axle?? Help!!!! |
02-08-2014, 02:11 PM | #4 |
Pebble Pounder Join Date: Apr 2007 Location: va beach
I think he's talking about the angle of your drive shafts.. If you compress the suspension and the noise goes away your top links need to be longe.
02-08-2014, 03:44 PM | #5 |
I had the same noise due to the plastic housing being warped, eventually it went away on its own....
02-08-2014, 04:07 PM | #6 | |
| Re: Loud sound coming from rear axle?? Help!!!! Quote:
Could just be that something got put together wrong inside the axle, or something is coming apart in there, like a screw backing out of the ring gear, maybe? | |
02-08-2014, 05:21 PM | #7 |
In the band for now. Join Date: Sep 2012 Location: roselle
take it apart and check it
02-08-2014, 05:48 PM | #8 |
So I have a the J/K rtr and I already waterproofed the truck but know my rear axle makes a loud ticking sound when I hold it up and test it. I put a lot of marine grease in both axles and I even pealed the seals of the bearings to put marine grease inside of them so they don't rust. I haven't driven the truck much and if you hold the rear axle you can feel vibration and that's not normal! So any suggestions on what it could be? I have taken the axle apart two times to make sure the gear mesh isn't tight and the gears appear to be okay he already did that...... Last edited by allanon1965; 02-08-2014 at 05:52 PM. |
02-08-2014, 07:58 PM | #9 |
02-08-2014, 08:06 PM | #10 |
To fix the confusion, my driveshaft angle is okay, at first with large shocks I have the angle was terrible and total didn't work but I say again with the droop kit it forces the driveshaft angle to be just right. I really don't know the problem, since I have plenty of experience on this chassis I've never seen anything like it. It doesn't matter if I compresses the suspension or not the ticking sound comes from inside the axle and you can here it from 5 feet away, which means its very loud!! And yes you can feel the vibration inside, the aluminum links are the proper size: 12.3 in wheelbase kit from axial. Is it possible that the marine grease is making binding issues inside?? Sorry if I make it confusing for you guys, I appreciate the help but as for right know the problem is not resolved. - axial 4x4 crawler
02-08-2014, 08:18 PM | #11 |
Clean the teeth of the diff very well tooth brush, tooth pick etc.. Make sure one hasn't picked up some trash clean the housing re-grease and enjoy..
02-08-2014, 11:57 PM | #12 |
After thinking about it, and re-reading your initial post, I think you may have gotten some debris in one of your bearings.
02-09-2014, 07:52 PM | #13 |
02-09-2014, 07:55 PM | #14 |
| Re: Loud sound coming from rear axle?? Help!!!! - yeah true, if that's the case then I'll just drive the truck for awhile and see what happens. Thank you for the help, I appreciate it. - axial 4x4 crawler
Loud sound coming from rear axle?? Help!!!! - Similar Threads | ||||
Loud coming from?? | CHOPPERMECH11 | Axial Wraith | 5 | 03-05-2013 08:44 PM |
rear axle sound ? | Subytuner | Axial XR10 | 11 | 06-18-2012 11:38 AM |
Servo makes alot of loud static crackling/popping sound when moving, normal? | StickyWheels | Losi Micro-Rock Crawler | 18 | 12-30-2011 05:06 PM |
rear axle shaft coming out of locker | MudboyNJ | Losi Mini-Rock Crawler | 2 | 11-09-2011 04:51 AM |
funny sound coming out of the rear diff | damige jnr | Venom Creeper | 12 | 02-23-2010 09:15 AM |
