Thread: slow progress G6 recovery vehicle.
Old 02-18-2014, 08:28 AM   #1
Default slow progress G6 recovery vehicle.
After building a wraith and taking it to our local craw / comp location and pulling lines I was told were impossible I've decided to reconfigure it a little and give it to my wife. I will be rebuilding her scx10 into a recovery vehicle for myself. Heres my hunting rig im using for inspiration. (Its a little rough, been in the trees a little while.)
tech712 is offline   Reply With Quote
Old 02-18-2014, 08:34 AM   #2
Default Re: slow progress G6 recovery vehicle.
donor vehicle1
doonor rig 2
Old 02-18-2014, 11:21 AM   #3
Being a Dodge fan really like the hunting rig. Going to build my SCX to look like the Ramcharger I'm building.
dodge80_89 is offline   Reply With Quote
Old 02-18-2014, 11:42 AM   #4
The rig is a beast. Top speed of 50mph@redline crawls slower than I walk. I've literally let it idle in 1st, got out, watered a bush and walked back upto it and jumped in. The 44"AG's on it are about 46-48" after a quick run down the highway to a lodge for lunch (back when it was licensed and road legal.)
I know one thing about this upcoming build. It will be heavy. The drivetrain will be bulletproof. It will have to have a couple winches. And like the hunting rig , the jib poles will mount to the bumper as well as the bottom of the headache rack. I have a lot of time to brainstorm howmI'm going to accomplish this one. Im as usual stuck at work for another 2 to 3 weeks.
Old 02-18-2014, 12:55 PM   #5
Look forward to see it when it's done. I've been stuck inside for the last 3 weeks watching my son while my wife is out of town so I've plenty if time researching my next rc build.
Old 02-18-2014, 07:08 PM   #6
Whats up with VP being out of stock on everything I need. Was about to drop some coin on curries , full ti link kit w cms and panhard goodies. 5 omf 1.9's knuckles n chubs as well as xvd's. Would have been nice to have them waiting at home for me when I got there.
Old 02-19-2014, 07:32 PM   #7
I may go with the honcho taco cab with a flat / utility bed and use the ar60 axles to mimic a 1 ton axle conversion. I already have a full wraith ti link kit with panhard bar. Just need the cms for the scx chassis.
Old 02-20-2014, 08:31 AM   #8
off the top of my head these are the parts on hand.
Vp wraith ti link se w/ panhard
Vp Ar60's front and rear w hd gears and lockers, underdrive rear r&p,
Built w/ full acer racing ceramic bearings. Full aluminim lockouts, chubs and knuckles.
Vp trans housing with hd motor plate, rrp internals with acer racing ceramics.
Tekin rx8 gen2 and roc412 3100kv
Axial TR honcho complete
Spectrum 3ch rx with dx3r pro
Proline slash big bore fronts x4
Vp kmc endro 2.2
Pit bull rock beast 2.2 (first gen)
Im sure there is more but its all I can think of this early.
I need to source...
a vp cms plate and panhard chassis mount
vp shock hoops
Various ss square and round tube
.010" ss 4" shim stock
A nice compact brazing torch setup
A mini mitre box and plenty of metal blades
Scale warn winch x2
.060 aluminum sheet stock
Arb scale snatch block x4
Scale shackles x8
Old 02-20-2014, 08:53 AM   #9
I forgot to add
A sewing kit
550 cord
Dremel bit kit w/ various stones and sanding barrels
A small can of 240 and 400 lapping compound
Blue locktite
Silver solder and flux
Lucas red n tacky
Anyone think of anything else?
This is kind of a shopping list for the build. Im still 2 to 3 weeks out with work atm.
Any ideas of a good source of supplies is always welcomed.
Old 02-20-2014, 05:27 PM   #10
Will the scx10 cms work with the wraith panhard and axle setup? On the scx chassis in a wroncho setup?
Old 02-20-2014, 05:44 PM   #11
Well it sure will look cool when your done. Can't wait to see more pictures as you get this build going.
CodesEmpire is offline   Reply With Quote
Old 02-20-2014, 07:19 PM   #12
This build is because my daughter who just turned 6 giggle with glee at the wheel of mommas or my scalers and in true g6 fashion I want daddys rig to be able to pull her out and or tow her home when she gets in trouble. I kinda like the idea of having a rig with all the recovery gear built in or attached to it. I already daydream about pull palls , tree savers, multi snatchblock rigging etc.
The idea that there will be no walking over to pick it up and figuring out the best way to rig up a recovery is almost an adventure in itself.
Perhaps my wife and daughter will have a better understanding of what it is like in the 1:1 world.
Old 02-22-2014, 08:31 AM   #13
Has anyone mixed and matched the scx10 cms and panhard mount with the wraith linkage for panhard bar and steering linkage? I dont have my rigs in front of me or id check for myself.
Old 02-27-2014, 08:49 AM   #14
No one has tried this?
On a positive note I may have aquired a sizeable space to setup a fabrication and maintenance bay. This is exciting. Im sue ive got over a month of installation and fabrication of tooling alone.
Fingers crossed.
Old 03-11-2014, 12:37 PM   #15
Going a slightly different direction with this one. It'll most likely be in the wraith section under my wraith build.
slow progress G6 recovery vehicle. - Similar Threads
MRC flatbed recovery vehicle and more stroker613 Micro Scale Rigs 11 12-08-2011 01:38 PM
MRC flatbed recovery vehicle and more stroker613 Losi Micro-Rock Crawler 3 12-05-2011 11:38 AM
Tamiya Recovery Vehicle ax10newguy Videos! 8 02-20-2011 09:23 PM
Dezfan's OHV Recovery Vehicle dezfan 1.9 Scale Rigs 37 07-16-2007 04:11 PM
work in progress very,very slow progress! rednekcrwlr Tamiya Clod Buster 6 12-18-2006 09:48 PM
