02-18-2014, 08:52 AM | #1 |
Newbie Join Date: Jan 2014 Location: middle river
| Jevne Racing Recon Brick SCX10 Battery Plate
will this work on the g6, and has enyone used it
02-18-2014, 10:20 AM | #2 |
Newbie Join Date: Feb 2014 Location: Menifee
| Re: Jevne Racing Recon Brick SCX10 Battery Plate |
02-18-2014, 10:51 AM | #3 |
Rock Stacker Join Date: Oct 2012 Location: Mid Coast
Should fit , but it's cheaper to use what axial gave you and DIY. |
02-18-2014, 10:56 AM | #4 |
Rock Crawler Join Date: Jul 2005 Location: Spartanburg
Hope so! I ordered mine this morning!
02-18-2014, 02:07 PM | #5 |
I wanna be Dave Join Date: Feb 2006 Location: r/c crawlin' heaven...
| Re: Jevne Racing Recon Brick SCX10 Battery Plate I use it. it's a great battery tray and I like the balance feel it provides with the battery location. I don't like the servo mount location on mine. it's useless in all configurations, but makes a great electronics mounting area. I hope this helps. |
02-18-2014, 04:41 PM | #6 |
Pebble Pounder Join Date: Jan 2009 Location: Parkesburg
I use one on my son's Honcho F-250 and it seems great. I have an interior in the F250 cab and there is a little interference but nothing a little work didn't fix. I'm planning on installing a servo winch in the front knockout at some point... Here's some pics. |
02-18-2014, 06:09 PM | #7 |
Looks good. Mine won't be making it in time for my comp but will set it up afterwards. I like the servo winch cut out as well!
02-18-2014, 08:26 PM | #8 | |
Newbie Join Date: Aug 2013 Location: In my house
| Re: Jevne Racing Recon Brick SCX10 Battery Plate Quote:
02-18-2014, 09:06 PM | #9 |
dont get me wrong i dont mind saving money by making stuff but when its a new build i like it to look clean, like it came from the factory that way and this tray keeps it that way
02-18-2014, 09:30 PM | #10 |
Quarry Creeper Join Date: May 2013 Location: on top of the rocks
I have a cms plate and I like it. I have a servo winch mounted on mine. The servo winch interferes with the panhard bar and axle mount and had to raise the winch up higher with spacers.Will have to raise servo winch up alittle more to align the cable angle for the bumper fair lead. Also noticed that full suspension compression on either side when wheel is turned at full lock there is interfearance with larger tires. Nothing alittle cutting to the battery location won't fix.
02-19-2014, 06:19 AM | #11 |
Pebble Pounder Join Date: Feb 2014 Location: Hampton Roads
Will this plate mount in the back like it does on the front? Sent from my SGH-M919 using Tapatalk |
02-19-2014, 11:41 PM | #12 |
02-20-2014, 04:27 AM | #13 |
02-20-2014, 04:58 PM | #14 |
Quarry Creeper Join Date: May 2012 Location: Industry
I just ordered the CMS plate myself. Question for you guys, I'm running curries and would like to get the panhard bar from Vanquish. Has anyone ran the currie panhard kit along with one of the JR battery plates?
02-27-2014, 03:53 PM | #15 |
Just got mine installed but the servo has been hitting the bottom of the plate. Now I have the CMS one so it seems to sit lower. But does your servo hit? Adding photo |
02-27-2014, 03:53 PM | #16 |
02-27-2014, 03:54 PM | #17 |
Pebble Pounder Join Date: Dec 2009 Location: Highlands Ranch
I have one on the Red Cow G6. Love it.
02-27-2014, 04:21 PM | #18 |
Does anyones axle mounted servo hit? I have 93mm shocks with currie axles. I'm thinking about either cutting mine for the servo to cycle up or replace it with the JR Recon cause it looks like its alot higher then mine is.
03-06-2014, 02:54 PM | #19 |
So I just got the CMS plate and im using the rc4wd cms and there is no way to make the plate clear without cutting off the whole parts that goes around the front of the cms which would remove one of the mounint points. What have you guys done?
03-29-2015, 02:34 PM | #20 |
I have a similar issue with this brick battery plate. But my problem is with running a SSD CMS kit. The closest plastic servo mount that holds the servo to the metal bracket bolted to the side rail hits a part of the brick so my solution was to move the brick further back and there's a wide slot section beneath the battery tray of the plate that allows you some wiggle room.
