Wiring options for body mounted lights? I am looking for more ideas on how to wire body mounted lights. Meaning, how to be able to connect/disconnect the wiring from the body for removal and installation. Currently, I have ring terminals on my front body posts, and on the body, so when they are put together it completes the circuit and the lights work. The only down side, is when the body twists the lights will flicker. I don't want to have to mess around with hard to access connectors or anything like that. What have you guys done that works well? Mike |
Re: Wiring options for body mounted lights? For my headlights and marker lights I used a 4 "AA" box with and on/off switch from radio shack. Cost about $3. Mounted in the back of my jeep body using gorilla tape. Could also do the same thing, but using a lipo. http://i982.photobucket.com/albums/a...psf93vjqrn.jpg |
Re: Wiring options for body mounted lights? I use male and female receiver wires, quickly connect and disconnect. I leave the wire with enough slack where I can set my jeep body to the side of the chassis for battery changes, without having to disconnect the wiring. |
Re: Wiring options for body mounted lights? Quote:
Thats exactly what i did using the 4 AA holder from raido shack i have mine mounted where the stock battery plate was http://img.tapatalk.com/d/14/02/28/gype5y4u.jpg Sent from my iPhone using Tapatalk |
Re: Wiring options for body mounted lights? Thanks guys. Looks like some good options. |
Re: Wiring options for body mounted lights? I have used RX connectors and Deans small ultra connectors. The reason why I would have more than one connector is because I have several light systems on several of my rigs. Here's what I used on my Jeep G6 http://i183.photobucket.com/albums/x...ps4ce2a5c2.jpg Build Thread: http://www.rccrawler.com/forum/axial...kit-build.html On my Jeep Wrangler JK I used two different types of small Deans ultra connectors a 4 pin and a 2 pin. http://i1200.photobucket.com/albums/...ps4ee17fd6.jpg http://i1200.photobucket.com/albums/...pse99e5c8a.jpg http://i1200.photobucket.com/albums/...pse17303eb.jpg Build Thread: http://www.rccrawler.com/forum/axial...t-project.html Same Deal with my old comp Honcho. http://i1200.photobucket.com/albums/...o/IMG_2870.jpg |
Re: Wiring options for body mounted lights? i have used both JST connectors as well as servo extentions cut in half (so you have male/female) and works great for me as i have headlights and taillights body mounted but powered through the receiver since i have controllers on them |
Re: Wiring options for body mounted lights? Yeah I ended up using Servo extensions like Richterat83. and Of course always leave it up to nissan_driver24 to have the cleanest looking wiring ever. To clean up my wiring, I use wire looming instead of shrink wrapping. Heres a pic for example, I'll have to dig up a body pic showing the LED wiring in the body but similar, using the wire looming and zipties to keep it high and tight =) http://i190.photobucket.com/albums/z...ps6d35b22e.jpg |
Re: Wiring options for body mounted lights? Lookin good, Guys! |
