03-21-2014, 10:35 PM | #1 |
Newbie Join Date: Jul 2010 Location: grass valley
| Thrashed 'er for a few years, what now?
I've been smashing around the block for a few years in my honcho and i'm wondering what I should do with it next. Still running original running gear (motor, shocks, links, drive lines, speed control and transmitter, ect). My stock shocks wont hold oil anymore and I am wondering what would be a good shock to switch to. The motor is also giving up the ghost and I would like to get something with a bit more torque. Just looking for any recomendations, not looking for competition quality but useable daily bashing. Any advice would be awesome.
03-21-2014, 10:39 PM | #2 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
Rebuild your shocks and pick up a 35t motor(holmes,tekin,rc4wd,etc) Also would be a good time to regrease your diffs and trans, but if its not broken, no need to replace it. |
03-22-2014, 04:05 AM | #3 |
Rock Crawler Join Date: Jul 2013 Location: Kansas City
| Re: Thrashed 'er for a few years, what now?
Get some Gmade zero shocks for @ $50 a set, grab a Holmes hobbies 13T Crawlmaster sport @ $40 and this motor has tremendous low end and bit more wheel speed than the stock 27T. Then you should be ripping up the neighborhood after that for a good long while.
03-22-2014, 04:11 AM | #4 |
Newbie Join Date: Feb 2014 Location: sacramento
^ like what he said get some gmade shocks . i have some and love it
03-22-2014, 09:21 AM | #5 |
Quarry Creeper Join Date: Mar 2013 Location: Wisconsin
I run duratrax big bores. Also you should maybe get a 35t motor. I run a tekin and never had any problems.
03-22-2014, 10:24 AM | #6 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
No problems with my BigBores....great shock, they've never leaked. Also look into a 35t HH or Brood motor....affordable, re-build able, great customer service from both of those vendors, great all around motors... |
03-24-2014, 10:06 AM | #7 |
Newbie Join Date: Mar 2014 Location: New Boston NH
I am running gmade zeros in my jp. I went with the 104mm but in hind sight I should have gone with the 94mm because the 104s jacked the truck way up in the air. Awesome shock though. Sent from my iPhone using Tapatalk |
03-25-2014, 12:04 PM | #8 |
Newbie Join Date: Jun 2011 Location: 'tooky
I've got a quick tip on a quick fix for loose axial rod ends... This works with the plastic ends, and the whole plastic links, with plastic or metal balls. Remove the link, pop out the ball, heat the tip of the link a lil with a lighter or heat gun and then press it straight down on the work bench just enough to squish it in a lil. It'll flatten the eye just a smidge, making the ball tight to press back in. Re-install and run for another year with near zero slop. Tightened up my jeep really well with no binding. ... ... |
03-25-2014, 01:03 PM | #9 |
RCC Addict Join Date: May 2008 Location: Southern,WV
If you're going to be doing mostly bashing with it.I'd say stick with a 27T.Just go with a different motor. I run a motor from Holmes Hobbies that's just right for those trucks that see more bashing then crawling..This is it. Holmes Hobbies LLC And the best part is it's only $11.99. It has great low end torque and has nice wheel seed.And you can't go wrong with a $12.00 Holmes hobbies approved motor...No need to spend a big bunch of money if ya don't have to.. And for the shocks...It could never hurt to do a basic rebuild...Or if you don't think the stock shocks will work for you any more.Go for the best shocks you can afford. Good shocks can make or break a good rig.IMO that is.Some like G made shocks Some like King shocks, and some like big bores...It's all in who you ask.I think you should do a little reading up on some shocks and see what ones would best suite you..And your style. |
03-25-2014, 03:58 PM | #10 |
| Re: Thrashed 'er for a few years, what now? Yes, but Traxxas Titan 21 turn 550 motor on 3s is great motor and cheap! I gear mine 13/56 32 pitch, crawls great and has some wheelspeed!
03-25-2014, 04:23 PM | #11 | |
Rock Crawler Join Date: Jul 2011 Location: Placer County
| Re: Thrashed 'er for a few years, what now? Quote:
i would just rebuild the shocks with new seals and oil, then replace the motor with something rebuildable. Integy 35t is probably your cheapest option. all of this should come in well under $50 including tax at your local hobby store. if you're on an OG honcho, you may not have the wildboar drivelines - if so, either get the reinforcement cups or upgrade to someone's wildboar takeoffs when they swap to MIPs. might not be a bad time to drop $30 on a set of Fast Eddy bearings for your whole rig - replace all of them and service the diffs/trans while you've got it open. | |
03-29-2014, 10:46 PM | #12 |
Thanks for all the input, got a 35t motor on order and a new set of shocks, nothing special just some basic amazon junk. Gonna save up for a set of gmade shocks, been hearing alot of good things about them. Will post pictures if I can figure out how. Also has anyone heard of a good frame mounted servo kit?
03-29-2014, 10:51 PM | #13 |
RCC Addict Join Date: Mar 2009 Location: Interior BC
| Re: Thrashed 'er for a few years, what now? |
03-29-2014, 11:22 PM | #14 | |
Quarry Creeper Join Date: Mar 2009 Location: Central WA
I run the Gmade XD piggyback shocks and love em. They leak a touch, but work very good. Super adjustable. Only thing I do not like is how big around they are, wish they were a tad skinnier. | |
Thrashed 'er for a few years, what now? - Similar Threads | ||||
Two years... | RD400 | Chit Chat | 72 | 02-20-2011 12:00 AM |
5 years.... | JeremyH | Chit Chat | 19 | 11-19-2010 01:50 PM |
thrashed it....time to upgrade. | crazyorigin | HPI Wheely King | 5 | 07-28-2010 05:46 AM |
