04-20-2014, 08:11 PM | #21 |
Rock Crawler Join Date: Feb 2009 Location: Wrightstown
| Re: Need Some Thoughts About This SCX-10
I think your best "upgrade" is gonna be your driving style. |
04-21-2014, 03:18 PM | #22 |
Rock Stacker Join Date: Apr 2013 Location: toledo
| Re: Need Some Thoughts About This SCX-10 |
04-21-2014, 03:39 PM | #23 |
I think I have an idea on what to get. (You Ready For It) A Mattzilla Truggy Chassis for the TF2 Body. That should be harder to bend right? Plus it has a lifetime warranty. The TF2 Body will probably be toast but an RC4WD Cab Exo-cage should help.
04-21-2014, 03:57 PM | #24 |
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
I can't believe you're bending the frame rails to being with. It's called "Scale" maybe you should try driving scale as well. |
04-21-2014, 04:26 PM | #25 |
| Re: Need Some Thoughts About This SCX-10 Yeah the track at the hobby shop was originally designed for XR-10 style vehicles not SCX-10's. So that could do it plus I basically launched the truck off the course once the tires bit into the rock and when your truck weighs 10lbs that much moving mass can cause some damage. Especially when landing on a concrete floor covered with a thin layer of carpet.
04-21-2014, 04:30 PM | #26 |
Ah, comp style crawling then, that can do it!
04-21-2014, 05:01 PM | #27 |
| Re: Need Some Thoughts About This SCX-10 Yep I put my SCX-10 to the test plus VERY LOW maintenance so last time I greased the trans and axles was when I built the truck in 2013 but I recently greased them back in February. I had also replaced the gears in the trans in October and didn't grease it then so the truck is not well loved. But i still love to drive it.
04-21-2014, 08:03 PM | #28 | ||
| Re: Need Some Thoughts About This SCX-10 Quote:
If the parts aren't holding up then they need to be upgraded. I drive like a 4 year old with ADD and my junk is built accordingly. Quote:
I'd grab something like a TCS x trail chassis and double it up if needed. | ||
04-22-2014, 05:59 PM | #29 |
We all see I bent the frame on my scx-10 right. Right. So hears my thought. A 1.9 wraith with SCX-10 axles. Seems like a god plan. Get a Wraith kit hot racing output. My scx-10 internals and electronics. Shouldn't bend in 2 places right? and it can have more scale details such as an interior and try to keep it at the same wheelbase-ish. Sounds like a great plan plus there is TONS of stuff for wrath chassis.
04-22-2014, 08:09 PM | #30 | |
Rock Crawler Join Date: Mar 2014 Location: Union City, CA
I am about to start mine! If you bent a Aluminum chassis though, your probably gonna break a wraith chassis. The Plus side is replacement parts are cheap and easily found. DO IT! Happy Crawling, | |
04-23-2014, 12:06 AM | #31 | |
Quarry Creeper Join Date: May 2012 Location: Portland
>>> 13.5T Novak <<< I think I found your problem. To answer you're question: the rumor is Integy parts are made of lower quality aluminum and break easily. Never owned anything made by them so I cant say for sure. There are several other routes you can take though.. honestly getting new Axial frame rails is pretty cheap, you can buy the whole frame rail and supports for about $50 on ebay right now (if that chassis you are looking at is $600 that's like 12 scx10 steel frames), or have someone make you come C-rails out of a heavier metal if you look through the vendors. or have someone like matzilla make you a truggy with an exo. I doubt the exo sold on rc4wd would do much to protect you launching your truck out of the course onto a concrete floor. Do you have steel gears in your tranny and diffs with mip drive shafts, beef tubes and aluminum chubs and knuckles? If not you might consider doing those upgrades. Most people will tell you that the plastic casings on the ax-10 axles will go over rocks better than aluminum will, so just keep the stock casings. (robinson, hot racing, strc and several others all make upgrade parts.) Maybe getting a bit of a higher turn motor like a 35t - 55t would help a little too.. and don't forget you can bend a steel frame back into shape, generally when aluminum bends under impact it cracks. Lastly, if you're more into go fast, a scx-10 might just not be the right truck as they are relatively fragile (IMHO) compared to something like a stampede 4x4. My overall opinion though is that a 10+ lb truck launching at high speed and falling 10 feet onto concrete is going to break something unless you land properly. Good Luck Last edited by rcwolf; 04-23-2014 at 12:20 AM. | |
04-23-2014, 07:32 PM | #32 | |
04-23-2014, 07:43 PM | #33 |
Quarry Creeper Join Date: Jun 2011 Location: butler pa
Intergy aluminum parts are very brittle, i would stick with axial frame and add some aluminum cross members.
04-23-2014, 09:15 PM | #34 |
Rock Crawler Join Date: Aug 2011 Location: south shore Ma
You just need a good tube chassis look on you tube for z71 vs Ralph. If that won't break it then I'm sure you won't either lol
04-24-2014, 08:22 AM | #35 |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
May I ask what were the circumstances for bending your frame?...Did it roll down a rocky hillside for 20ft?...did you smash into something? Seems even the most normal hard driving doesn't bend frames...I don't comp but that doesn't seem to be an issue for those who do and they try to break things. What the heck are you doing with it that you bent 2 frames? You can strengthen the frame with changing around some of the bracing or even some strategic welding in certain areas. You can even partially box the stock frame in areas of weakness if you really needed to. |
04-24-2014, 02:31 PM | #36 | |
Tags |
advice, scx-10 |
Need Some Thoughts About This SCX-10 - Similar Threads | ||||
SCX-10 TJ Unlimited thoughts | GrapeApe | Axial SCX-10 | 3 | 12-04-2012 09:15 PM |
Any thoughts on SCX-10 build??? | RCchomp | Axial SCX-10 | 6 | 12-17-2010 12:09 PM |
