Thread: need some wheel hex help guys
Old 04-19-2014, 11:17 AM   #1
Default need some wheel hex help guys
picked up some Dick Cepek beadlocks for my honcho , the problem im having is I cant get the center cap on as the axels are too long.. im looking for a wider hex.. the stock honcho ones are about 5mm thick.. does anyone make a 8mm thick aluminum hex?? any help is appreciated.. links?? part numbers?
thanks guys
4orty6and2 is offline   Reply With Quote
Old 04-19-2014, 12:32 PM   #2
Default Re: need some wheel hex help guys
Yeah...you can find the wheel hexes on ebay. I had the same problem with my wheels too.
Johnnysplits is offline   Reply With Quote
Old 04-19-2014, 03:11 PM   #3
I just used some plastic ones from taraxacum when I did my vp chubs and knuckles. I wanted to try the plastic ones before I bought the aluminum ones, but haven't found a reason to replace them yet. I believe they're around 8-10mm. I didn't measure. They work great and were cheap.
babristow is offline   Reply With Quote
Old 04-20-2014, 10:40 AM   #4
all I can seem to find is having to buy 2 sets of traxxas ones either the 3654 plastic or 6869 aluminum
Old 04-20-2014, 11:50 AM   #5
why not just shorten the axles a bit...I presume you are talking about the threaded portion sticking out too far. I had the same issue with my axial universals that did this and I just ground down the ends a bit and it is fine now. I still have plenty of threads for the nut to hold on to...
allanon1965 is offline   Reply With Quote
Old 04-20-2014, 05:04 PM   #6
just figured if something comes up down the road, ide rather have the thread.. and a little wider stance wouldn't hurt anything either
need some wheel hex help guys - Similar Threads
Wheel Hex Help jlsandkes Axial XR10 6 10-18-2011 08:45 PM
wheel hex? toka100 General Crawlers 4 09-20-2011 10:56 PM
Wheel hex Onebdgti Axial AX-10 Scorpion 2 05-19-2011 01:11 PM
Taking hex out of wheel without damaging wheel? bi_eep Newbie General 8 03-06-2008 04:58 PM
wheel hex yukon635 Newbie General 4 07-01-2006 01:26 PM
