05-11-2014, 10:04 AM | #1 |
Newbie Join Date: Apr 2014 Location: Columbus
| Hubs Unlinited JK
This is my First RC of any kind. So please bare with on everything that I post,say, or ask. Here is a run down everything I have done so far. Also have DIY shackles, tow rope, bungee cords, snow chains. JK Unlimited body w/ trimmed rear fenders & body, trimmed front body, tire mounted to rear of cage Clearanced inside frame rails Trimmed and flushed mounted front & bumpers Flipped and tucked sliders Stock waterproofed electronics 21t Titan 550 motor w/12 tooth pinion and stock spur Tranny flipped 180* 1/2" servo arm Shock post mounted battery Shock post tower brace Axial 61-90mm Aluminum Shock Set - 7mm Piston Vemon 2s lipo 20C 2000 7.4v Intergty 101mm 30* bent links front custom length rear links Stock tires/rims |
05-11-2014, 10:26 AM | #2 |
| Re: Hubs Unlinited JK
here are the pics or at least a link.had to figure that one out. better to just be a member. |
05-11-2014, 10:45 AM | #3 |
| Re: Hubs Unlinited JK |
05-11-2014, 11:39 AM | #4 |
RCC Addict Join Date: Feb 2008 Location: your back yard
Welcome, and nice start to a lifetime addiction. Whats your plan for it?
05-12-2014, 05:21 AM | #5 |
Plans includ 2.2s ,lights, winch, rear steer or cutting brake. Other then that it's a great rig. Also got both sets of links own. Lower links are 101 with 30* bend at the end. Upper links are 101 with 30* bend is the center. This gives a huge amount of space to fully compress the suspension
05-13-2014, 09:36 AM | #6 |
Pebble Pounder Join Date: May 2014 Location: Canada
Nice unit. Sent from my iPhone using Tapatalk |
05-15-2014, 07:22 PM | #7 |
Went out the other day after work for a little pay time and ended up breaking a C Hub. So who is running and liking what for alu. Hubs/ knuckles???? Since I was fixing things I make some new steering linkage and drag bar. Make out of some 8-32, traxxes link ends, and some brake line. Working pretty darn good. Turned out better then the links I tried to make. Though I am having some interference with the drag bar and frame rails. A longer servo horn fixed the problem I think. Also got the battery moved to the front shock towers, along with shrink tubing the motor leads to the ESC. I think this is going to be a good move. Now with the electronics on both sides more up front along with the battery it really has put a lot of weight forward. Hoping I can get out an retune my shocks now that I changed some things around. Flipped the springs so longer on bottom,shorter on top. Really having a hard time getting them all the same. Thinking about going with a droop setup or just springs. Hope that the new links front and rear help out also. {\rtf1\ansi\ansicpg1252 {\fonttbl\f0\fnil\fcharset0 HelveticaNeue;} {\colortbl;\red255\green255\blue255;\red153\green1 53\blue153;\red255\green255\blue255;} \deftab720 \pard\pardeftab720\sl360\partightenfactor0 \f0\fs26 \cf2 \cb3 \expnd0\expndtw0\kerning0 \outl0\strokewidth0 \strokec2 \ } |
06-15-2014, 10:37 AM | #8 |
Hubs Unlinited JK - Similar Threads | ||||
GiveAway!!! Custom Anodized Shift Hubs (Adjustable Offset Hubs) By Lattice Innovation | BC-Brian | General Crawlers | 116 | 05-17-2014 08:24 AM |
GiveAway!!! Custom Anodized Shift Hubs (Adjustable Offset Hubs) By Lattice Innovation | BC-Brian | General Crawlers | 126 | 02-14-2014 01:03 AM |
GiveAway!! Custom Anodized Shift Hubs (Adjustable offset Hubs) by Lattice Innovation | BC-Brian | General Crawlers | 118 | 06-18-2013 05:39 PM |
