05-24-2014, 10:03 AM | #1 |
Rock Crawler Join Date: May 2013 Location: Somewhere in space
| Gmade 103mm shocks very stiff. Help needed!!!
Hello, I haven't been on the forums in a while but anyways lately I swapped the shocks between my honcho and jeep. My jeep is a mud truck and it has the Gmade 103mm aeration shocks equipped on it. I noticed that they are very stiff and don't have much rebound. I had these on my honcho for about 4 months and didn't realize it. (My honcho has 110mm king shocks now). I have a droop kit from 3racing or whatever so it helps but I don't get much flex out of it. I would say it flexes about 3 inches, which isn't much. What should I do? I could put 15wt oil in them to try to fix it but that may be to thin. I built these shocks and they seem to work fine but it is not acceptable with the flex and stiffness. My jeep is totally waterproof. Any help would be great, thank you! - axial 4x4 crawler P.S.- Those aeration shocks are very hard to adjust! I regret buying them now. |
05-24-2014, 01:08 PM | #2 |
| Re: Gmade 103mm shocks very stiff. Help needed!!!
Come on guys I need some help ASAP! Please stop looking and give a suggestion at least. I'm not trying to be rude but seriously?!
05-24-2014, 02:32 PM | #3 |
Newbie Join Date: Feb 2014 Location: Tucson
Airation shocks are just like any other shock that doesnt use a resivoir, it is possible that you may have the shocks too full of shock oil or your springs are very stiff
05-24-2014, 03:39 PM | #4 | |
| Re: Gmade 103mm shocks very stiff. Help needed!!! Quote:
- axial 4x4 crawler | |
05-24-2014, 05:35 PM | #5 |
Pebble Pounder Join Date: Jan 2013 Location: Raleigh, NC
I got some GMade shocks recently for my SCX10 and found the springs were way to stiff. I had a full set of Proline springs laying around and tried some different combos, ended up with very soft springs and now the suspension / shocks work amazingly well.
05-24-2014, 09:23 PM | #6 |
Pebble Pounder Join Date: Feb 2004 Location: Born in a crossfire hurricane
Same here, I thought the g-made springs were too stiff. I picked up the g-made soft spring set and still didn't like it. I'm running a soft set of pro-line springs now and it seems to do much better. I'm even using the slider and the second spring on my g-made 103 shocks.
05-25-2014, 08:02 AM | #7 | |
05-25-2014, 08:03 AM | #8 |
| Re: Gmade 103mm shocks very stiff. Help needed!!! Thank you for your input. Do you know what the part number is on the springs you used?
05-25-2014, 11:11 AM | #9 |
Rock Crawler Join Date: Jul 2013 Location: Manchester
The scx10 springs are tight but fit over the gmade cartridges .. At which point you have a dual spring set up ... And spring options ...I run 35 weight oil and have plenty of flex but I'm also running a tf2 chassis with a " wroncho " set up specifically for mud Sent from my iPhone using Tapatalk |
05-25-2014, 12:17 PM | #10 | |
05-25-2014, 12:45 PM | #11 |
I used the pro-line rear slash springs #6063-04. Here's how they fit
