Thread: Offset wheels for Pitbull rockbeast
Old 06-02-2014, 06:37 PM   #1
Default Offset wheels for Pitbull rockbeast
I just installed the Vanquish stage 1 kit which has the 8 degree knuckles. I am wanting a set of beadlock offset wheels to go with the 1.9 Pitbull Rockbeast I just ordered so I can have more clearance. Any suggestions?
Derek108 is offline   Reply With Quote
Old 06-02-2014, 09:10 PM   #2
Default Re: Offset wheels for Pitbull rockbeast
Wider wheel spacers. Vanquish should make some wider wheel hexes for the scx10 so that we don't have our tires rubbing the inside of our tires. Hint hint.
im gunna crawl is offline   Reply With Quote
Old 06-02-2014, 09:13 PM   #3
Yeah. What are some good beadlock wheels to get for the pitbull rockbeast ?
Old 06-02-2014, 09:15 PM   #4
I have a set of traxxas wheel hub tall off sets on them now that give me the clearance
Old 06-03-2014, 05:26 AM   #5
If you use the Traxxas wide hex (I suggest the blue aluminum over the gray plastic) you can get away with a .475 hub. I prefer the .600 on my rigs but that's just me.
VP has some nice wheels as you know, and Locked up has some nice wheels that are SLW hub compatable and are a little less costly.
gdb85 is offline   Reply With Quote
Old 06-03-2014, 12:42 PM   #6
I have a set of aluminum mayhem wheels for sale .... Huge offset .. Hex mount so you don't need hubs
Purptr8r is offline   Reply With Quote
Old 06-03-2014, 12:49 PM   #7
VP Wheels and Hubs is one way to fix it. I had to put Integy 7mm wide hexes on my JK to get my RC4WD DC7's to clear my VP chub/knuckle setup with 1.9 Rock Beasts.
You can run .475 hubs on VP wheels with plenty of clearance on the stock SCX10 hexes.
Ty@Tekin is offline   Reply With Quote
Old 06-04-2014, 09:29 PM   #8
Yeah I talked to VP today and decided to go with the 600 offset and knuckle weights
Offset wheels for Pitbull rockbeast - Similar Threads
Vanquish SSZ Series Scale Wheels featuring PitBull RockBeast XOR Tires and C.I. Foams jeeper_05 Tires and Wheels 65 10-03-2011 04:36 PM
