CMS for scx10 dingo Hello I have used the search button. I was just seeing if anybody knew about a good cms kit for the dingo? Thanks Sent from my iPhone using Tapatalk |
Re: CMS for scx10 dingo Search scx cms there are lots. Vanquish makes a good one. It's a bit pricey tho |
Does it work for dingo though? Sent from my iPhone using Tapatalk |
Re: CMS for scx10 dingo Yes all scx10's are the same essentially |
Why does the rc4wd cms kit say "not suitable for dingo"? Sent from my iPhone using Tapatalk |
Get the vanquish one. I love mine. Easy installation http://img.tapatalk.com/d/14/06/03/3a6u7ypa.jpg Sent from my iPhone using Tapatalk |
That's installed on 11.4 wheelbase? Sent from my iPhone using Tapatalk |
12.3 wheelbase Sent from my iPhone using Tapatalk |
I need one for the 11.4 though Sent from my iPhone using Tapatalk |
It will install in the dingo Sent from my iPhone using Tapatalk |
I wish I had a better pic to show u Sent from my iPhone using Tapatalk |
If u still feel unsure just call them. They will answer all your questions. Sent from my iPhone using Tapatalk |
I wish I could know if anybody else had the vp cms installed on the dingo, I don't want to spend $100 on something that doesn't work Sent from my iPhone using Tapatalk |
Re: CMS for scx10 dingo , I don't want to spend $100 on something that doesn't work Sent from my iPhone using Tapatalk[/QUOTE] Thats 125.96 with shipping |
Re: CMS for scx10 dingo My understanding is that since the cms kit come with an upper link to 3 link the front, it's the wrong lenght and that's why it doesn't work on the 11.3 dingos. That and where it mounts in the frame rails is further forward on the 12.3 honchos. I am running the rc4wd on my truck. I have dingo links in the rear and honcho up front so I have the proper geometry up front but I have the shorter wheel base that my chevy body needed. http://www.rccrawler.com/forum/axial...10-action.html Hope that helps |
Re: CMS for scx10 dingo The actuall CMS part of the kit will work fine, axle mount, chassis mount & panhard bar. The rest of the kit is useless for you because all the links are for 12.3 WB. VP doesn't sell just the CMS part...yet. Another option if you have the coin to drop is buy the kit, use the CMS portion, make your own upper link, sell off the rest of the Ti links in the FS section, some one will buy them. A crazy option but an option none the less. |
Re: CMS for scx10 dingo If you can make your own links, why not get the Blue Monkey DIY kit? DIY CMS with Panhard, Blue Monkey RC It's under $80 for everything but the upper link which you'd need to make yourself, but the drag link and tie rod will fit either rig. I'm running it and love it! |
Re: CMS for scx10 dingo Quote:
So what upper link are you talking about, did you do this to a dingo? |
Re: CMS for scx10 dingo I'm running the Hand Brothers kit on my Dingo. I don't have any pictures at the moment, but it works fine. I did have to clearance a frame crossmember for the upper link, and I think my panhard might even be bent a little to clear the frame on compression, but it does work very well. I can try to take some pictures tonight if I remember. I realize the Hand Brothers isn't available anymore, but the RC4WD one is identical as far as I know, so it should work the same. |
Why does the rc4wd cms say "not suitable for dingo" if it actually is? Sent from my iPhone using Tapatalk |
