Thread: Cross over steering
Old 06-16-2014, 12:54 PM   #1
Default Cross over steering
Did a search, didn't find anything similar.
When making my steering links, I had the idea of rigging a custom cross-over (EDIT: "Inverted T") setup:
The advantage to cross-over verses the typical on-the-knuckle would be reducing the stress on the steering knuckle itself, making it less prone to breakage.
I ultimately decided to use the OTK steering anyway, because its so darn simple, but I wanted to share the cross-over photo, as it might spark some ideas for others.
On the topic of alternate steering set-ups, has one ever tried to built a inverted-Y, like on the older Wranglers?
Might be a fun challenge, plus an extra touch of scale-ness.
summerof95 is offline   Reply With Quote
Old 06-16-2014, 01:05 PM   #2
Default Re: Cross over steering
The stock steering setup IS crossover. You have built an inverted-t setup. http://www.pirate4x4.com/tech/billav...ngresearch.htm
Calderwood is offline   Reply With Quote
Old 06-16-2014, 01:37 PM   #3
Actually, THIS IS essentially the stock set-up, but with DIY components (which I hadn't seen done before). It's the various upgrade kits that tend to change it to OTK.
And by golly, I think you're right about the terminology.
The image in my head when building it was a kit sold by Rugged Ridge, labeled as a "cross over conversion."
It features a drag-link, connected to an end-to-end tie rod.
Guess that's just their marketing team.
First time I've heard it referred to as an inverted T, though.
In any case, this is what I built.
Old 06-16-2014, 02:10 PM   #4
Moderator Rule Breaker
eric113's Avatar
My old Y steering..
eric113 is offline   Reply With Quote
Old 06-16-2014, 02:35 PM   #5
Oh... Nice.
Did you drill and tap through the link?
I'd love any info you have on the construction of it.
Why did you replace it, any problems with it?
Old 06-16-2014, 03:42 PM   #6
eric113's Avatar
Originally Posted by summerof95 View Post
Oh... Nice.
Yes, everything is drilled and tapped.
No issues. I had full throw. Just wanted go back to standard steering linkage.
Old 06-16-2014, 04:09 PM   #7
~THE SCALE SHOP~
I like yours a bit better eric. keeps the steering rod at full length for a longer arc, and less bump steer at full droop.
STANG KILLA SS is offline   Reply With Quote
Old 06-16-2014, 04:40 PM   #8
Inverted Y causes toe change as the suspension cycles.
Old 06-17-2014, 07:57 AM   #9
Yes, very slight toe-out as it compresses. But I doubt it'd be noticeable on a low speed RC.
Eric, were your links solid, or all-tread and brake line?
Any trick to drilling them?
Old 06-17-2014, 08:07 AM   #10
eric113's Avatar
It does cause some toe out. But I never really noticed on mine.
My links were solid aluminum drilled and tapped for 3mm set screws. just used a jeepin Doug drill bushings, drill press, 3mm tap&drill set.
Cross over steering - Similar Threads
Steering with cross canyon jk brute won't turn to right mtgrizzlymn General Crawlers 1 12-29-2013 04:43 PM
Enduro Cross twisted Chit Chat 7 02-05-2008 08:22 PM
