07-15-2014, 04:24 PM | #1 |
Newbie Join Date: Nov 2013 Location: canada
| what causes front wheel to surge
when i lift truck up and apply low throttle the back wheel turn slow and smooth but the front ones arnt so smooth the kinda jolt if ya know what i mean any idea whats wrong ? also when i am driving truck as soon as i let of the throttle it skids to a stop how do i make it so it rolls i have a holmes hobby moter and esc
07-15-2014, 04:40 PM | #2 |
Rock Crawler Join Date: May 2012 Location: Columbus
| Re: what causes front wheel to surge
it skids because of drag break its supposed to do that so u can stop on a incline and the chatter might be from the angle of the drive shaft being to steep pics would help |
07-15-2014, 04:40 PM | #3 | ||
| Re: what causes front wheel to surge Quote:
commonly the drive shafts do not get reinstalled properly, as there are alignment marks (arrows) on the shaft slugs indicating the proper phasing. An out of phase drive shaft will often shake, shudder and what you said. could also be that something is binding at the front axle possibly hair wrapped up in the wheel bearing/cv shaft ? Or even that the bearings themselves are corroded or damaged. Quote:
^ a useful thing, for a crawler. IMO DB is usually controlled by the ESC. If it's the stock Axia/castle ESC purchasing the Castle link... allows the consumer to use their PC to adjust the drag brake's calibrations 0-100% | ||
07-15-2014, 07:04 PM | #4 |
thanks for the reply its actually a holmes hobby ESC and ill check the drive shafts thanks
07-15-2014, 07:06 PM | #5 |
Newbie Join Date: Nov 2013 Location: Australia
As above ^^^ your driveshaft is out of phase
07-15-2014, 08:26 PM | #6 |
Rock Crawler Join Date: Jul 2009 Location: Victoria Australia
| Re: what causes front wheel to surge |
07-16-2014, 03:45 PM | #7 |
Newbie Join Date: Feb 2014 Location: Tucson
a drive shaft out of phase on this scale........really sounds like you have something binding up or too much drag brake or you need to reset your throttle, brake and nuetral posistions
07-16-2014, 04:15 PM | #8 |
| Yes...this scale driveshaft with its joint out of phase will certainly cause binding and jumping...seen it many times...really gets noticable as the driveshaft angle increases...
07-16-2014, 08:16 PM | #9 |
Rock Crawler Join Date: Oct 2011 Location: Fairfield
Saw this the other day with mine, It was the Driveshaft grub screws were loose. But I also have the old style with no through holes on the pinion/yoke. Just added some locktight and retightened.
07-16-2014, 09:23 PM | #10 |
Rock Crawler Join Date: May 2013 Location: Somewhere in space
Yeah that's just drag brake there as it was mentioned before. Just align all of the driveshaft pins to were they are all aligned including the front axle all the way to the rear axle. The manual says something about this so as long as you do that then it will stop doing that. Trust me, when I got my first sc10 I was wondering the same damn thing but now I have three different scx10's so I know what I'm talking about lol.
07-17-2014, 01:29 AM | #11 | |
Pebble Pounder Join Date: Sep 2012 Location: Netherlands
Some people don't like to spend $20 on something they only need once, others have a real computer while the castle software only works on Windows. http://docs.axialracing.com/instruct...e_AE-2_ESC.pdf | |
07-17-2014, 03:38 AM | #12 |
Here's an explanation Axial SCX10 Dingo Axle Chatter & Fix - YouTube |
what causes front wheel to surge - Similar Threads | ||||
surge watts | Ty | Electronics | 8 | 10-06-2009 07:44 PM |
Surge Protector help | bigdodge88 | Chit Chat | 8 | 03-21-2009 06:21 PM |
surge problem | kling-on | Electronics | 1 | 01-07-2008 10:48 PM |
Surge Problem | Halfahemi | General Crawlers | 3 | 08-17-2006 04:15 PM |
