Thread: driveshafts issue after 4 links upgrade
Old 08-09-2014, 01:58 PM   #1
Default driveshafts issue after 4 links upgrade
Hi
Today I have upgraded my scx10 honcho to custom 4 links (front & rear)
After I did the upgrade, I noticed issues in the throttle performance, I do suspect it is from the driveshafts, the behavior is as shown in the below video
Scx10 drive shaft issue? - YouTube
Appreciate your support
questionare is offline   Reply With Quote
Old 08-09-2014, 02:15 PM   #2
Default Re: driveshafts issue after 4 links upgrade
Did you line up the drive shaft? The cross member thing you have use on the front axle screwed down? I forget to screw mine down and had front axle shudders.
Sailingeric is offline   Reply With Quote
Old 08-09-2014, 02:26 PM   #3
I bet your driveshafts are at too much of an angle. If you compress the springs and axles toward the truck does it stop? If so you'll have to clock your axles a bit to account for that.
friz is offline   Reply With Quote
Old 08-09-2014, 02:27 PM   #4
I had to do the same thing with me scx10 after I added longer shocks, but any suspension change could do the same thing.
Old 08-09-2014, 04:44 PM   #5
my bet is the the drive shafts were not reassembled correctly
and are needing to be phased (aligned)
there should be index marks > | < visible at both ends of the DS
or simply align the pins of the universal joints
TacoCrawler is offline   Reply With Quote
Old 08-09-2014, 04:51 PM   #6
Compress the suspension on the front axle and try it again.
WHITE-TRASH is offline   Reply With Quote
Old 08-12-2014, 01:10 AM   #7
Thanks guys,
It was the angle, I lengthen the upper links and the chatter disappeared.
I returned to 3 links in the front since I have the servo mounted to the chassis (rc4wd kit) and the links hit the 4 links truss on the axle.
Now I am having another issue, the servo is turning one way fully, and barely turns the other way.
I zeroed the servo, however, still the same, I feel that the front axles moves against the servo when it ttries to steer that direction.
Appreciate your feedback
Old 08-12-2014, 01:21 AM   #8
Sounds like you didnt install the panhard link....
allanon1965 is offline   Reply With Quote
Old 08-12-2014, 01:54 AM   #9
Thanks for the feedback, I bought this car used. Originally it didn't came with panhard link, and was working correctly
The Kit I use is similar to the one in the below link
http://www.rccrawler.com/forum/rc4wd...rvo-mount.html
Old 08-12-2014, 03:13 AM   #10
Not familiar with that one.
The one i bought came with the panhard link in the kit..it was also from rc4wd....
Old 08-12-2014, 05:29 AM   #11
Thanks, appreciate if others can help
Old 08-13-2014, 12:55 AM   #12
I have a question,
Do the drag link should be parallel to the link connecting the two wheels?
At what angle should be the drag link? I feel it is on a high angle in my current setup which may caused the issue, and one note, if I left the truck of the ground, the steering works great at both sides, the issue is on the truck is on the ground
Thanks again,
Old 08-13-2014, 05:08 AM   #13
Just an update, inhale solved the issue, it was the front axle angle,I clocked it and the steering worked correctly
Thanks
driveshafts issue after 4 links upgrade - Similar Threads
Steering Links Upgrade hueyfisher Axial AX10 2nd-gen 10 02-06-2013 06:04 PM
ckrc upgrade driveshafts/ yokes Jgraser1 Axial AX-10 Scorpion 12 07-16-2012 05:53 AM
MIP SplineDrive Shafts???? Upgrade driveshafts AsILayDying Axial SCX-10 13 07-23-2011 07:00 AM
