08-29-2014, 08:28 PM | #1 |
Newbie Join Date: Aug 2014 Location: selah
| Wroncho
anybody have an idea of the most common problems building a wroncho? is it better to use the wraith skid or scx10 skid and bend the links to fit? seems to me the wraith skid would be better and maybe a bit easier. Thanks! |
08-29-2014, 09:15 PM | #2 |
Newbie Join Date: Nov 2011 Location: Colorado Springs
| Wroncho
I used the wraith skid and didn't have really any problems Sent from my iPhone using Tapatalk |
08-30-2014, 06:10 AM | #3 |
Quarry Creeper Join Date: Jun 2006 Location: L-Town
| Re: Wroncho
I suggest using the scx skid and making ur links or 3linking it. depending what body you use u might have a problem with body posts cuz the frame is so wide
08-30-2014, 07:45 AM | #4 |
Rock Crawler Join Date: Aug 2010 Location: Esko
I have done it both ways. With scx10 skid you will need to bend links to clear the drive shaft and with the wraith skid I wanted to use wraith links to so I had to move the body back to line up wheel wells and bend a U shaped bracket to extend the frame a bit to clear the servo. I also needed to use the wraith trans for the longer output or you could make a longer driveshaft probably. I'm not sure if you could just use shorter links up front.
08-30-2014, 09:16 AM | #5 |
Pebble Pounder Join Date: May 2008 Location: tucson
| Re: Wroncho
i used the wraith skid so i didnt have to bend the links all funny and then made shorter links to get the wb i wanted. the best thing to do is try both skids and see which works better for your application.
08-30-2014, 09:29 AM | #6 |
Quarry Creeper Join Date: Jun 2012 Location: pomona
| Re: Wroncho
I used Wraith links and SCX skid. Didn't have to bend a thing and the wheels line up perfectly and everything clears.
10-27-2014, 04:37 PM | #7 |
Quarry Creeper Join Date: Mar 2014 Location: Athens, Al
| Re: Wroncho Hate to bring up an older thread, but in your last pic of the underneath with the wraith links. The way the lowers are mounted on the outside of the frame rails. does it night bind or rub when it articulates?
Wroncho - Similar Threads | ||||
wroncho | Chodey24 | 2.2 Scale Rigs | 5 | 08-29-2012 10:08 AM |
wroncho help | steveo 561 | Axial SCX-10 | 2 | 08-24-2012 09:19 PM |
