08-30-2014, 07:28 AM | #1 |
Quarry Creeper Join Date: May 2013 Location: Knoxville
| RC4WD Winch question
I want to get a RC4WD winch. What size battery does it need 2s or 3s? I have a small 3s 450mah battery will this battery have enough run time with the winch to make multiple pulls if I have a full day of crawling? If not how powerfull is the winch on 2s? I can run it from my 2s battery I use to power the esc (5000mah) but I was thinking 3s would be better.
08-30-2014, 12:09 PM | #2 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: RC4WD Winch question
I haven't bought one yet, but it can be run off a 3s.
08-30-2014, 12:14 PM | #3 |
Quarry Creeper Join Date: Apr 2013 Location: perkasie
I have mine running 6v through the rx with a castle bec and a heyok controller......its a 9lb gelande 2 and its all powered from a 2s 5200 lipo....truck/winch/lights will run close to 4hrs with no problems...i don't know this to be true but I think 11v might not be good for that winch motor....theres a called poolo (I prolly have that wrong) that sells robotics parts that has replacement motor gearboxes that will work like that though Sent from your moms house |
08-30-2014, 02:08 PM | #4 | |
| Re: RC4WD Winch question Quote:
08-30-2014, 08:53 PM | #5 |
I run the RC4WD Warn 9.5 W wireless controller powered directly off my primary 3S. so far... no issues. spools quickly IMO. Probably less so if supplying only 6v. I personally confirmed with RC4WD that my combo is warrantied when using 3S power. I would have concern running the winch from the power supplied thru the RX. Not sure what the amp draw could be when the winch is under load. In my thinking... Supplying power to the winch thru the RX could cause issue and possibly damage the RX. But then... a user posting here... said it works for them @ 6v. |
08-31-2014, 03:21 AM | #6 |
I can run it with the small 3s I'm just worried that 450mah won't be enough to get me through the day. I could get a 800mah-1000mah battery for it but much higher than that and I would be worried about weight and killing the stock electronics. If I run it through the receiver I will run a bec.
RC4WD Winch question - Similar Threads | ||||
New RC4WD winch controller question | Mrdick | Electronics | 11 | 01-31-2014 09:11 AM |
RC4WD winch question... Newb! | NormanAbsher | Newbie General | 9 | 07-28-2013 01:27 AM |
Rc4wd winch question | mikeman84 | Electronics | 3 | 04-16-2013 10:20 PM |
RC4WD Bulldog winch question | jeepscx10 | Electronics | 2 | 02-02-2013 02:51 PM |
3ch rc4wd winch question | turbotron | Electronics | 1 | 09-29-2012 11:28 AM |
