12-30-2014, 05:42 PM | #1 |
Rock Crawler Join Date: Sep 2013 Location: New Orleans
| A'nudder China JK build
Well after admiring the China made 2dr JK body for a while now, I decided to shorten the WB of a Rubicon roller I had saved for another project. This build will be rather slow but I have some of the components needed to start. Ill be using the GCM front motor mount kit and the gear head rear shock relocation kit. I have an idea on how to mount this shell, but if you know or have seen some rather trick ways of doing it, I'd like to know about it. Drivetrain and electronics will consist of a HH torque master pro 27T, Hot Racing steel gears, Hot Racing alloy trans. case and Junfac shafts. ESC will likely be a CC sidewinder-SCT. Last edited by tokdl; 01-13-2015 at 06:02 PM. Reason: Adding photos |
12-30-2014, 05:44 PM | #2 |
| Re: A'nudder China JK build
Here are a few of my reference pics.
01-08-2015, 08:03 PM | #3 |
Drive train starting to come together.
01-13-2015, 03:00 PM | #4 |
Rock Crawler Join Date: Aug 2011 Location: Baton Rouge
Lovely star bro ! I see you are getting that Jeep right from the jump! Plus the wheels and tires keeps you close to scale with your reference pics ! Subbing and watching intently!
01-13-2015, 03:11 PM | #5 |
Thanks my friend! Ever since I've laid eyes on one of these bodies I've been wanting to build around one! It's turned into my primary build now lol! Looking forward to trying these MTZ's!
01-13-2015, 05:58 PM | #6 |
A few shots of the drive line issue I'm having. Looks like I'll have to cut some of the floor pan and fire wall away to clear for the third shaft.
01-13-2015, 06:52 PM | #7 |
Pebble Pounder Join Date: May 2014 Location: Mississauga Ontario Canada
Actually, yeah, you know what?!?!??! Those stock rims being so correct for the truck ... that makes it POP for me. VERY big points for scale, imho. (and i'm in no way a "scale guy" - i'm all about the crawl) |
01-13-2015, 07:02 PM | #8 |
| Re: A'nudder China JK build Thanks for the compliment. There was no way I was doing this build with out the JK wheels lol. Much appreciated! |
01-13-2015, 07:52 PM | #9 |
Any progress on the drive shaft issue yet?
01-13-2015, 08:04 PM | #10 |
| Re: A'nudder China JK build |
01-13-2015, 09:00 PM | #11 |
Thats whats up....Did you holla fr8 yet?
01-13-2015, 09:04 PM | #12 |
Going to leave him a PM in a few, looking at some builds right now... not looking good.
01-14-2015, 04:19 PM | #13 |
Any good news ?
01-14-2015, 04:33 PM | #14 |
Not much news on the drive train issues, the new shaft will be here Saturday, meanwhile I'm toying with different internal spring rates for the rear RC4WD dampers.
01-15-2015, 01:36 PM | #15 |
My new soldering iron tips just came in today. Time for electronics installation. Sent from my N9510 using Tapatalk |
01-15-2015, 01:40 PM | #16 |
01-15-2015, 04:49 PM | #17 |
Did you get busy with that heat gun yet? Anxious to see if everything goes well with the body !!! Sent from my N9510 using Tapatalk |
01-15-2015, 04:54 PM | #18 |
Nah, shaft comes in Saturday, don't want to jump the gun until I'm sure I know what I have to melt I'm praying it's a small amount! Anything new with the Brute so far?
01-15-2015, 09:25 PM | #19 |
Man.............the station with the tips from ebay is good to go! Just finished putting leads to the 35t with a breeze ! This weekend is all about getting my electronics sorted out as well as hit my new 3s battery with some Dean plugs!
01-15-2015, 09:27 PM | #20 |
So surprisingly my third shaft showed up today and I got right to work on finding out how much I had to trim for clearance. Luckily the majority of the space that needed to be removed was under the center console and behind the dash out of view. However I did need to notch a small hole that can still be seen from the passengers side interior. Thankfully it's small enough that I can either cover it with black styrene or place the female passengers hand bag in front of it next to her ankles. Obviously if I had gone with more ride height, I probably wouldn't have had to trim anything, but I'm trying like hell to keep this JK as close to factory looking as possible, so I didn't want to lift it any higher than what it is now. Plus, with this being such a short WB rig, I can see this being slightly top heavy. Last edited by tokdl; 01-15-2015 at 09:37 PM. |
A'nudder China JK build - Similar Threads | ||||
My China made JK Build | TriggerMan | 1.9 Scale Rigs | 52 | 12-08-2016 07:25 AM |
China and the Olympics. | JasonInAugusta | Chit Chat | 5 | 08-12-2008 07:49 PM |
