01-12-2015, 01:08 PM | #1 |
Newbie Join Date: Dec 2014 Location: swindon uk
| Is this normal amount of noise
Hello all. Ive recently finished building my first scx10 (dingo) Took it for its first run today.. is it normal to make this much noise?? Seems very clicky?? Noisy scx10 gearbox??: http://youtu.be/fvAGGYQo4Is |
01-12-2015, 01:22 PM | #2 |
Rock Crawler Join Date: Feb 2012 Location: Tennessee
| Re: Is this normal amount of noise
It kinda sounds like your pinion/spur mesh is too loose. If that's not it try disconnecting the drive shafts and running it, then front and rear by their selves to isolate the noise. |
01-12-2015, 02:28 PM | #3 |
Thanks. Ill have a look. Im thibking it could be that as it makes a completely doffrent noise in fwd and rev. Also is it normal for the drive shaft to touch the housing?? |
01-12-2015, 06:17 PM | #4 |
Quarry Creeper Join Date: Dec 2014 Location: The Angels
Yea that clearance looks normal, ie. stupd close. As mentioned above check pinion/ spur mesh. Also, check to see if the driveshafts are indexed properly. You have to line up the marks on the ends of the half-shafts or you could have significant chatter. Hope this helps |
Is this normal amount of noise - Similar Threads | ||||
Drag Brake amount? | GTcrawler | RC4WD Trail Finder 2 | 2 | 09-03-2012 01:09 AM |
Installed BEC and new servo...is noise normal? | jvalason | Axial Wraith | 3 | 12-28-2011 12:06 AM |
high pitch noise? normal? | JAKEF150FX4 | Electronics | 5 | 11-14-2005 01:38 PM |
