02-02-2015, 05:45 PM | #1 |
Pebble Pounder Join Date: Mar 2012 Location: Port Angeles
| Toyzuki chassis and cms kit
Here's some pics of my scx10
02-02-2015, 05:47 PM | #2 |
| Re: Toyzuki chassis and cms kit
That's a castle 1410 motor for reference
02-02-2015, 05:48 PM | #3 |
My homemade stainless links and the Toyzuki axle mount
02-02-2015, 07:39 PM | #4 |
I wanna be Dave Join Date: Aug 2004 Location: san jose
Well how does it work?
02-02-2015, 07:43 PM | #5 |
Have not had it out yet. This same running gear with stock frame and axle mounted servo worked very well. I can only expect that this setup will work even better.
02-03-2015, 05:44 AM | #6 |
Everone is waitting for Video & pic...
02-03-2015, 07:08 PM | #7 |
I will see if I can get some at the comp on Saturday. I do everything on my iPhone so I might have to have someone else load it since I'm not very tech savvy in that department
02-03-2015, 07:51 PM | #8 |
Rock Crawler Join Date: May 2012 Location: Upland
are you toyzuki? Or is that his screen name? Does that cms and panhard work for stock chassis rails? |
02-03-2015, 07:51 PM | #9 |
02-03-2015, 07:51 PM | #10 |
Cool.....
02-03-2015, 08:17 PM | #11 |
No I am not Toyzuki. That is his screen name. He is a vendor on here. A quick search should get you to him. This cms does work on the stock frame as well. The regular kit comes with a servo mounting plate also. You will just need your own links and a couple screws. The way I have it set up I am getting full suspension travel and only just a tiny bit of bump steer almost not noticeable. I do recommend running a 3mm tap through all the threaded holes before getting started.
02-05-2015, 01:41 PM | #12 | |
RCC Addict Join Date: Nov 2008 Location: Central, WA
| Re: Toyzuki chassis and cms kit Quote:
02-05-2015, 01:45 PM | #13 |
Oooh there they are!! Hard to tell if your links are equal length (they should be). But it looks like their not parallel. Try shimming the servo down, or putting shims between the horn and the rod end until their parralel. They need to swing in the same arc, so parallel is a must to get rid ofbump steer!
02-05-2015, 02:50 PM | #14 |
I tapped them before I even tried using any hardware just as a precaution. I know my links are exactly the same length but are within about 2mm. Looking at the steering in person I'd say they are really close to parallel. I really like how the axle mount gives you multiple locations for the panhard and that's why I chose this kit over the other ones since I am running the narrow xr steering with this chassis. I also like to support local too. Fit and finish is excellent everything is spot on and I didn't have to mess with anything besides figuring out my links which was to be expected. I will try to post up what lengths I used when I get home this evening to try and make it a little easier for others.
02-05-2015, 10:39 PM | #15 |
Rock Stacker Join Date: Nov 2014 Location: Morgan Hill
Could you take a pic with a top view? Please and Thank you. |
02-06-2015, 10:11 PM | #16 |
Will this do?
02-06-2015, 11:21 PM | #17 |
Yup. Thanks |
02-07-2015, 12:16 AM | #18 |
You're welcome. Sorry for the delay I've been really busy
02-12-2015, 11:31 PM | #19 |
| Re: Toyzuki chassis and cms kit |
Toyzuki chassis and cms kit - Similar Threads | ||||
CMS kit help | m1009cucv | Axial SCX-10 | 4 | 02-14-2013 05:32 AM |
rc4wd cms vs hand brothers cms kit | bronc4now | Axial SCX-10 | 4 | 05-16-2012 07:14 PM |
CMS kit for a Xtrail chassis | OfnaJoe | 1.9 Scale Rigs | 4 | 12-09-2010 10:48 PM |
