03-09-2015, 01:44 PM | #21 |
Quarry Creeper Join Date: May 2014 Location: Burlington, ON Canada
| Re: What battery are you using for your scx10?
I have two of these -- Turnigy nano-tech 6000mah 2S2P 65~130C Hardcase Lipo Pack Never reached the LVC. They last a while. |
03-10-2015, 05:50 PM | #22 | |
Newbie Join Date: Jan 2015 Location: Western MA
| Re: What battery are you using for your scx10? Quote:
03-10-2015, 06:10 PM | #23 |
Rock Crawler Join Date: Mar 2006 Location: Dogpatch
Valuehobby & Motion RC both have good lipo packs for cheap money.Currently running 3s 2200 Turnigy's & Admiral packs.
03-10-2015, 06:15 PM | #24 |
Quarry Creeper Join Date: Mar 2014 Location: San Antonio
SPC 2S 5000mah great batteries, hard case, great price and your choice of connector. SPC LiPo Power, Lithium Polymer (LiPo) Battery Pack; 5000mAh, 50C, 2S, 7.4V Hard-Case |
03-10-2015, 06:54 PM | #25 |
Pebble Pounder Join Date: Apr 2013 Location: traverse
I'm in the proses of running two 5200mah 3s parallel , one on each rc4wd rock guard. I will be looking for lower mah batterys but the 5200mah 50c dynamites I all ready have . I got the idea from a thread I came acrossed the other day. Last edited by billy bones; 03-10-2015 at 06:57 PM. |
03-10-2015, 06:57 PM | #26 |
Rock Crawler Join Date: May 2012 Location: Upland
Picking up two 5Ah 2s hobby people packs tonight. Used 20 a piece Sent from my SPH-L720 using Tapatalk |
03-10-2015, 07:15 PM | #27 |
Rock Crawler Join Date: Nov 2011 Location: clarksville,ar
03-11-2015, 09:01 AM | #28 |
Rock Stacker Join Date: Nov 2014 Location: newark
i use turnigy 2200 2s packs they work great for 10 bucks!
03-11-2015, 11:07 AM | #29 |
Newbie Join Date: Jul 2014 Location: Charlotte
Venom 2200 20c 3s
03-11-2015, 11:12 AM | #30 |
RCC Addict Join Date: Oct 2012 Location: Norcal
Venom 6400mAh 30c 11.1v The all day battery. |
03-11-2015, 11:31 AM | #31 |
Zippy 5000 mah 45c 11.1v I get tired before it does... |
03-11-2015, 11:50 AM | #32 |
Pebble Pounder Join Date: Jun 2014 Location: White Plains
I have made my own batteries and exclusively drive with them. I prefer LiFePo4 because they are safer and have more even power over the discharge of the battery, better than LiPo. They also have 2000 DoD (Depth of Discharge) cycles to 80%, LiPo is about 200-300. Also a 3S LiFePo4 is about 2.5v higher nominal voltage than 2S LiPo, it sits between 2S and 3S LiPo giving a nice middle ground. Other advantages... more resistance to over/under charging and they like to be fully charged and left alone! That being said I have found all brands LIE about C rating because people want a "betterrerrer" battery. C is a multiplier of capacity. If you have a 5,000mah battery with 20 C it will discharge at 100 amps. A 2,500 mah at the same C rating will discharge at 50 amps. This is *CONSTANT* discharge. Peak discharge which lasts about 10 seconds is much more important when crawling and is about 2x of the batteries standard C rating. To put it another way, a battery discharged at 30C will have a 2 minute life time. Discharge at 1C = 60 minutes, 2C = 30 minutes, ..., 30C = 2 minutes, ..., 60C = 1 minute, ..., 120C = 30 seconds. The math is 60(minutes)/C no matter the capacity. In practical terms if you have a 30 minute drive time on a battery you have an average discharge of 2C. If you are driving a 5,000mah battery then you have an average discharge of 10 amps (10,000 ma) People have complained about the "punchiness" of a battery with a lower C rating. However their ESC can only handle 50 amps, for example, and the battery is more than capable of exceeding that. We are humans and are subjective. Many experiments have been done about this and we perceive better performance with a "better number." If you really want to compare the quality and capability of batteries get the internal resistance from the manufacturer. The lower the better and that is the REAL measure of quality for a lithium based battery and is verifiable. Feel free to read about it here Battery Testing, Test Methods and Procedures In summary if you have a 50amp ESC and a 5,000mah battery you can't use more than 10C. Last edited by infodragon; 03-11-2015 at 12:40 PM. Reason: Changed mah to ma. |
03-11-2015, 01:25 PM | #33 |
Newbie Join Date: May 2013 Location: Cleveland
Turnigy Nano Tech batteries from Hobby king are very hard to beat Radio Control Planes, Helicopters, Cars, Boats, FPV and Quadcopters - Hobbyking* |
03-11-2015, 01:51 PM | #34 |
Newbie Join Date: Dec 2012 Location: Volusia County
Since I mostly bash with my SCX10, I bought two 5000mAh NiMH batteries and use Deans plugs. I've been using them on and off for about two years with no issues. Just this week, I picked up my first LiPo battery... a 2S 5000mAh 25C battery from Venom with Deans plugs. I've charged the battery, but haven't used it yet. I'm not expecting to be much of a difference, but I will find out. |
03-11-2015, 02:17 PM | #35 |
| Re: What battery are you using for your scx10? |
03-11-2015, 02:34 PM | #36 | |
I use dual 2200mah 3S LiPo's wired/plugged parallel. So combined... 4400mah ^ they weigh less... and fit better when mounted on the sliders. JMO run time nets around 3 + hours per charge. but run time will be dependent of motor wind and gearing. mounted to factory original sliders mounted to custom built sliders ^ both utilize similar mounting methods. And utilize lexan saddles mounted atop the sliders. Very easy to make yourself. .................warning.................... don't mount a LiPo battery directly to a metal slider surface... If shifting causes any abrasion to a LiPo battery... It could cause a fire and burn/melt your chassis/components. Last edited by TacoCrawler; 03-11-2015 at 02:37 PM. | |
03-11-2015, 06:27 PM | #37 |
Thanks for all the replies and links. Last question: Can a traxxas xl5 esc handle/capable of being powered by a 2s lipo, or should I stick with nimh with that setup? |
03-11-2015, 08:55 PM | #38 | |
did you read the owners manual ? https://traxxas.com/sites/default/fi...LVD%20Addm.pdf ^ switching is necessary so that the ESC's mode includes a LiPo low voltage cut off. edit: I don't think that esc would be ideal for a crawler... as I'm not reading where it mentioned that it has "drag brake" capabilities !? https://traxxas.com/products/parts/e...5waterprooflvd seems like it'd work swell for faster RC cars Last edited by TacoCrawler; 03-11-2015 at 09:04 PM. | |
03-12-2015, 08:29 AM | #39 | |
| Re: What battery are you using for your scx10? Quote: I'm thinking of raising them up one hole. Currently 4 holes showing above hoops in front / 1 in rear. Here you go.... Last edited by GodSpeed999; 03-12-2015 at 08:36 AM. | |
What battery are you using for your scx10? - Similar Threads | ||||
scx10 battery | landozer18 | Newbie General | 5 | 08-07-2014 10:11 PM |
What battery and charger for SCX10 TR? | fyrfytr | Newbie General | 15 | 03-24-2010 03:27 PM |
battery in scx10... | gmanning37 | Axial SCX-10 | 2 | 02-21-2009 09:07 PM |
