Thread: Scx10 transmission gears
Old 06-14-2015, 04:13 PM   #1
snapon boy's Avatar
Default Scx10 transmission gears
Has anyone used the hot racing hard anodized aluminum gear set? Or the steel case hardened set? I need some new gear want a good set that will last. Thanks
snapon boy is offline   Reply With Quote
Old 06-14-2015, 08:10 PM   #2
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
Default Re: Scx10 transmission gears
Hot racing steel or the axial steel are great choices.
JohnRobHolmes is offline   Reply With Quote
Old 06-14-2015, 09:00 PM   #3
snapon boy's Avatar
Thanks JRH. I just got your sold output diff and the cheep metal gear I had didn't fit. So I'm ordering the hot racing ones and bearings to rebuild the whole thing.
Old 06-14-2015, 09:11 PM   #4
No prob man. If you want to take an extra step, assemble it with a little regular engine oil and spin it from the output with a drill until it quiets down and spins smoother. Then clean out the break-in sludge and put a moly grease in.
Scx10 transmission gears - Similar Threads
Scx10 metal transmission gears sanny632 Axial SCX-10 6 01-13-2014 11:01 PM
transmission gears aebstract Axial SCX-10 4 07-10-2012 11:01 AM
transmission gears ax10newguy Formula Offroad 19 06-04-2011 07:00 AM
X-F Transmission gears ratbastard XTM Crawler 2 01-16-2005 12:09 PM
