06-16-2015, 06:51 PM | #1 |
Newbie Join Date: Mar 2015 Location: Jonesboro
| SCX10 CRC Edition
Finally came in Casey Currie Edition I couldn't keep it stock for too long paint the spyder bumper set and tire rack Went ahead and bought some 1.9 axial beadlocks and painted the 1.9 rings silver Stock CRC wheel And threw some XD shocks on while I was testing her out Order some vanquish lights to replace the stock plastic rigid LEDs but these will work for now Lots of upgrades to come and please feel free to give feed back not sure how to make it more scale looking so any feedback in welcome thanks for looking Sent from my iPad using Tapatalk |
06-17-2015, 07:38 PM | #2 |
Rock Crawler Join Date: Mar 2006 Location: Dogpatch
| Re: SCX10 CRC Edition
Looks great.How do you like your GMade shocks? Do they leak yet? Carry on & have fun
06-18-2015, 09:25 PM | #3 |
No leaking yet but I think they worked better on my wraith I'm lookin for some proline scalers to put on my scx Sent from my iPad using Tapatalk |
06-18-2015, 10:52 PM | #4 |
Pebble Pounder Join Date: Aug 2014 Location: NoVa
Did you have any trouble removing the BFGs from the stock wheels? I am considering going with the Axial Beadlock Wheels as well... |
06-19-2015, 11:54 AM | #5 |
No just got some boiling water threw them in there for about 12 mins then got them out pulled the bead then flipped them and put them back in the water and repeat the same process till they come off and at first it will look like ur tearing the bead but ur not just make sure u let them boil good and be care wear gloves the foams do hold water and it is hot lol Sent from my iPad using Tapatalk |
06-19-2015, 11:57 AM | #6 |
| Re: SCX10 CRC Edition Got my vanquish LED wired up finally and mounted to the body EXTREMELY bright hooked up to 3s alone and does any one kn if the stock axial ridge LEDs and LED simple controller can handle being wired straight to a 3s battery or basically piggybacking off the vp LED Sent from my iPad using Tapatalk |
06-19-2015, 12:00 PM | #7 |
| Re: SCX10 CRC Edition This is how it's wired as of now I would like to run all light off one battery and run receiver,esc and motor off another one and can a pro4 4000kv handle 4s Sent from my iPad using Tapatalk |
06-19-2015, 01:12 PM | #8 |
I joined the Band! Join Date: Dec 2014 Location: Earth
The Pro4 4000kV is only rated to 2S, the 3300 is rated to 3S, the 2400 and 1900 are 4S rated.
06-20-2015, 10:47 AM | #9 |
I've been runnin a 50c 5200mah 3s lipo with the MMP and it hasn't over heated or even gotten hot but I also have it geared as low as possible and I just crawl I don't bash it or anything major but I do play for almost an hour and half ever day just about Sent from my iPad using Tapatalk |
06-20-2015, 10:49 AM | #10 |
Do u kn if the simple led control has can Handle 3s plug straight to it for all the light like the vanquish light? Sent from my iPad using Tapatalk |
06-20-2015, 11:15 AM | #11 |
Rock Crawler Join Date: Nov 2014 Location: Grimcity, On
I doubt it, they are setup for 5v, on a rx.
06-21-2015, 07:08 PM | #12 |
Ok thank u Sent from my iPad using Tapatalk |
SCX10 CRC Edition - Similar Threads | ||||
Crc edition color matching roof help | SoCal Crawlr | Axial SCX-10 | 3 | 09-13-2015 02:29 PM |
Project "Rent-A-Jeep" a CRC Edition JK with a twist or two | Hoosierdady | Axial SCX-10 | 13 | 05-29-2015 11:04 AM |
Poison Spyder/CRC Edition Axial JK with a ESS-One sound module | Hoosierdady | Scale Videos! | 0 | 05-01-2015 09:09 AM |
CRC edition with some scale upgrades | Cultus | Axial SCX-10 | 14 | 01-16-2015 01:51 PM |
