07-01-2015, 08:48 PM | #1 |
Newbie Join Date: Mar 2015 Location: Portland
| What foams?
I've done a search on foams, and all the results i'm seeing are from 2011 (probably user error). it looks like the nova Dual Stage 1.9s are pretty popular. I'm running the stock foams that came w/ the rock beasts, sealed, and am getting a good bit of rollover at the front. I haven't weighed my truck but I'm guessing it probably weigh 6lbs with the battery mounted pretty much over the front wheels. Thanks in advance for your tips! |
07-01-2015, 09:27 PM | #2 |
Rock Crawler Join Date: Apr 2014 Location: Portland
| Re: What foams?
Can't go wrong with Crawler Innovations Lil' Nova 1.9 Dual Stage Lil' Nova 1.9 Dual Stage 4.50T Foam Pair (2) Just get the right size for your tires. With Battery up front, I like Med foams up front and soft in the rear since there is less weight. But then again, I could be doing it backwards. IMO.. |
07-01-2015, 11:56 PM | #3 |
Quarry Creeper Join Date: Aug 2013 Location: Bullard TX
| Re: What foams? CI Deuces Wild There is an option in the Deuces Wild that's made for the Rock Beast. You could do the Lil Nova 4.25 or 4.50 as well, either way you go will be better than the stock foams. |
07-02-2015, 08:57 AM | #4 |
Rock Crawler Join Date: Nov 2014 Location: Grimcity, On
| Re: What foams?
Novas are nice, I have to meds in treps stretched on 2.2s and they work great. I've seen deuces on the trail and they seem pretty capable, although the truck with deuces weighed in around 9lbs.
07-02-2015, 12:03 PM | #5 |
Pebble Pounder Join Date: Sep 2008 Location: philly
| Re: What foams?
I also say lil nova, with vented tires ftw.
