07-27-2015, 06:37 PM | #1 |
Newbie Join Date: Mar 2015 Location: NY
| My SCX10 deadbolt drives slightly to the right.
Hey all, I'm still new to the rock crawler scene. Today I started to finally put all the parts I ordered into my scx10. Before installing all these parts, my truck has been slightly driving to the right. I don't know why. I figured maybe my new parts would help correct the alignment. I installed the rear lockouts, front knuckles, and hubs. I also installed a new waterproof servo onto it with new aluminum steering links. After all that was installed I switched it on and it works! Problem is that when I test drove it, it still drives slightly to the right and it's starting to worry me. Please help! Thanks in advance! |
07-27-2015, 06:52 PM | #2 |
Newbie Join Date: Jun 2015 Location: U.S
| Re: My SCX10 deadbolt drives slightly to the right.
You can adjust the steering trim on your radio to make the deadbolt track straight.
07-27-2015, 07:45 PM | #3 |
Quarry Creeper Join Date: Nov 2010 Location: Sarasota, Florida
| Re: My SCX10 deadbolt drives slightly to the right. |
07-27-2015, 08:14 PM | #4 |
Thanks for replying, How would I go about doing that? Thanks again! |
07-27-2015, 08:26 PM | #5 |
Newbie Join Date: May 2015 Location: San Diego
On top of your stock controller, open the black cover- adjust the knob furthest to the left "ST-TRIM" either clockwise or counterclockwise depending on which way it is pulling. Slightly turn it while driving straight until you get it where you want it.
07-27-2015, 08:43 PM | #6 |
If the TX's trim adjustment is way off center after centering the servo's horn... You can remove the servo horn... ...set the TX's trim adjust to center. then re-align(center) the horn as you reinstall that. Now your TX trim adjustment will have equal left/right adjustment at the TX's trim adjust. If it's a new RTR out the box... it should be fairly centered already and likely just needs a TX trim adjustment. |
07-28-2015, 01:16 AM | #7 |
Quarry Creeper Join Date: May 2015 Location: RRW
I bet it's a 25t output on your servo. I put a 2mm spacer on my steering link between the link and rod end making the link a hair longer. Because looking at the radio and seeing it displaying not perfectly center after I adjusted the trims disturbs my OCD. Axial part # AXA1414
07-29-2015, 09:49 PM | #8 |
Ty all for the help. I adjusted the st trim on my controller and it worked. Thanks again
My SCX10 deadbolt drives slightly to the right. - Similar Threads | ||||
My Scx10 Honcho Slightly moded | ablaydes | Scale Videos! | 2 | 11-07-2011 07:44 PM |
