08-09-2015, 02:15 PM | #1 |
Rock Crawler Join Date: Dec 2013 Location: Sacramento
| Question: Mounting an RC4WD winch to Rock Armor G6 Front bumper
The bumper appears to use smaller hardware than the winch mount plate. Don't have the winch in hand yet but the website made it appear to mount with M3. Do you just pick your holes and drill them out? It almost looks like M2 barrel heads are supposed to go through the bottom based upon the holes supplied in the bumper. Sent from my SM-N910V using Tapatalk Last edited by DowntownScience; 08-09-2015 at 02:19 PM. |
08-09-2015, 03:52 PM | #2 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
| Re: Question: Mounting an RC4WD winch to Rock Armor G6 Front bumper
The Warn uses the middle 4 hole pattern. You use the stock hardware that is used to mount the winch plate to the winch (goes up though the bottom). The winch mount plate is not used.
08-09-2015, 04:00 PM | #3 |
Thanks. So then that hardware is M2? Because nothing larger than that is going through those holes! Sent from my SM-N910V using Tapatalk |
08-09-2015, 06:46 PM | #4 |
Yes it is M2. That hardware for mounting comes with the winch when you buy it
08-09-2015, 07:20 PM | #5 |
| Re: Question: Mounting an RC4WD winch to Rock Armor G6 Front bumper |
08-09-2015, 07:30 PM | #6 | |
| Re: Question: Mounting an RC4WD winch to Rock Armor G6 Front bumper Quote: Sent from my SM-N910V using Tapatalk | |
08-09-2015, 07:32 PM | #7 |
08-09-2015, 07:48 PM | #8 |
the G6 bumper and all the newer RRA bumpers are drilled directly for the Warn. Piece of cake and much easier to mount than the old 3Racing winch in the vid linked too |
08-10-2015, 12:39 PM | #9 | |
08-10-2015, 01:55 PM | #10 |
Quarry Creeper Join Date: May 2015 Location: RRW
I have this bumper and had the same issue. The hardware that came w/ the RC4WD winch didn't work. Drilling the hole out to fit an M3 doesnt work because it still isn't big enough for the cap head on the screw to sit down flush in the bumper. I had to first remove the mounting plate then buy M2 X 6 screws and then it mount it direct to the bumper with those.
08-10-2015, 01:58 PM | #11 |
Thank you FloridaCralwer. I have a bunch of those for the beadlocks. Sent from my SM-N910V using Tapatalk |
08-17-2015, 08:49 AM | #12 |
Just to confirm...it's just as Florida crawler said. Remove fairlead and mounting plate. Secure into bumper with 4 M2x6 barrel head screws. The screws I had for the beadlocks were M2x10 so I just cut them off and cleaned up the ends with a dremel. Sent from my SM-N910V using Tapatalk |
Question: Mounting an RC4WD winch to Rock Armor G6 Front bumper - Similar Threads | ||||
Rc4wd tough armor bumper light mounting? | Chisholm | Axial SCX-10 | 0 | 02-08-2014 08:11 AM |
