08-10-2015, 01:09 PM | #1 |
Pebble Pounder Join Date: May 2013 Location: lemont
| tekin redline gen1-will not fit??
i'm sure this is answered here somewhere,but i couldn't find it...... i have a wraith and wanted to try a scx10--. i wanted to put my tekin redline gen-1 21.5 brushless motor in it.. BUT it wont fit?? it hits the upper y-arm and nut where it meets the frame.. any suggestions?
08-10-2015, 01:18 PM | #2 |
| Re: tekin redline gen1-will not fit??
What gearing are you running? A smaller pinion and spur could allow you to slide your motor over enough to clear the link mount screw.
08-10-2015, 01:25 PM | #3 |
no gearing at all.. the can jut wont sit flush against the motor plate.. its too long..
08-10-2015, 01:28 PM | #4 |
do you have to put spacers under the trans to raise it up?
08-10-2015, 01:29 PM | #5 |
Rock Crawler Join Date: Feb 2010 Location: in a Fishbowl watching time go by
Fit right on to my wraith no mods at all
08-10-2015, 01:33 PM | #6 |
thanks,but thats a wraith.. i have a wraith with a roc412.. fits no problem.. but the link set-up's are completely different
08-10-2015, 01:43 PM | #7 |
You can reverse the screw holding on the upper link to gain some more clearance (screw on the inside, locknut on the outside of the frame). Upper links that use rod ends instead of the RTR plastic upper 3 link provide some more clearance as well.
08-10-2015, 02:01 PM | #8 |
i did the bolt flip..i can get the top bolt in but still no love on the bottom... its stock so i don't have the 4 link rod end uppers.. it really never occurred to me that it wouldn't fit. took it for granted because of my wraith..
08-10-2015, 05:31 PM | #9 |
do you just trim the inside of the link?
08-10-2015, 06:25 PM | #10 |
is the Tekin 21.5 brush less closed end bell motor can longer then an Axial brushed closed end bell motor can ? just curious... because I installed a Axial 55T stock brushed motor into my Wraith without any issue. Last edited by TacoCrawler; 08-10-2015 at 06:27 PM. |
08-10-2015, 07:20 PM | #11 |
The tekin is 3mm longer than axial 20t. On the wraith the link is being and to the side.... but on the scx10 it ends up UNDER the motor... pushing it up.. which angles it and does not allow you to bolt it to the mounting plate... this can,t be that uncommon? I see people using these motors...what's the trick/mod??
08-10-2015, 07:37 PM | #12 |
I've run the Redline Gen1 in and SCX. It's no magic trick, but the recipe seems to be ditching the upper Y-link for a true 4 link (which should be done for more than just motor clearance issues) with a narrower rod end. Running a buttonhead bolt (instead of a cap-head) from the inside of the frame with the nut on the outside, and run gearing between 80/17 and 87/14-12 to keep the motor away from the bolt. In the end, my particular setup has maybe a hairs width of space between the can and the head of the bolt. |
08-10-2015, 09:01 PM | #13 |
| Re: tekin redline gen1-will not fit?? |
08-10-2015, 09:46 PM | #14 |
I joined the Band! Join Date: Dec 2014 Location: Earth
Unbolt the transmission, bolt the motor down and push it as close to the trans case as possible. Then re-install the transmission. It's not rocket science, but it does involve a little more work than the shorter and/or tapered can 540's and you need to use the button head screw from the inside. I just put a 55mm long straight can 550 (Reedy 550-SL) in my SCX10, it actually fit without removing the transmission but would have been a little easier if the trans is pulled first. If you want more room for gearing options, trim the Y-link so the head of the screw sits closer to the frame rail. Last edited by Eric0424; 08-10-2015 at 10:11 PM. |
08-10-2015, 10:10 PM | #15 |
| Re: tekin redline gen1-will not fit?? If you need more clearance trim away the red section of the Y-link in the picture below. Last edited by Eric0424; 08-11-2015 at 12:23 AM. |
08-11-2015, 07:44 PM | #16 |
first off-- i want to send out a big thanks to all who replied!!!. my issues were multiple. 1. unbolting the trans-- motor still wouldn't fit flush--ended up trimming a 1mm off the plastic part that the gear cover would bolt on to. it pushed down on the motor can not allowing it to be bolted in flush/rotate so you can get both bolts in.. 2.. flipping that link bolt. After those repairs-- the motor gentle rests on top of the link screw head. a slight flex and you can get a gap.. I'm sure it will rub on the can some,but i don't see it being a issue. Really--THANKS AGAIN FOR ALL YOUR SUGGESTIONS..john |
08-14-2015, 04:57 AM | #17 |
Rock Stacker Join Date: Apr 2009 Location: sheilock
what do you mean its not fitting right...i just put in and still have a tekin redline gen1 17.5 in my scx10 just got to run the bolt backwards! |
08-14-2015, 05:59 AM | #18 |
| Re: tekin redline gen1-will not fit?? From reading his last post, it sounds like the back of the gear dust cover on the transmission was causing some fitment/clearance issues. I didn't have that problem, but the cover is very close to the motor. If the motor plate and/or cover are machined and molded a little off I can see it being a problem.
08-14-2015, 07:15 AM | #19 |
RCC Addict Join Date: Nov 2008 Location: Bunnell, Fl.
Glad to hear you got it figured out. As the other post above says, trim y link if needed, use a shorter screw and your good to go. I've run all kinds of motor / esc combos in my rigs with no major issues. |
08-14-2015, 08:15 AM | #20 |
I've never had an issue that I remember (probably flipped that nut without a second thought), but looking at the RTR scx10 on the shelf here I see it is a really tight squeeze for straight can brushless motors. The Puller Pro 540S fits fine, but the 540 would certainly hit that nut without the suggested changes. The SCX10 platform was designed before brushless was good enough to run in a crawler, so those few millimeters matter!
tekin redline gen1-will not fit?? - Similar Threads | ||||
Issue with MMP/17.5 Redline Gen1 | Selser420 | Electronics | 7 | 05-17-2015 12:08 AM |
